Results 1 to 10 of 13
Thread: Three Bowls
    Aug 2008
    NorCal, USA
    495
    Three Bowls
    The first bowl was turned at a bowl turning class I am taking. I was sitting furthest away from the box of blanks, so I got one of the orphans that nobody else wanted. It was a misshapen, worm eaten chunk of Black Walnut with some rotten bark that I thought may be interesting inside. It has stunning figure to it (if that is the correct terminology). The bowl is 7 ¼” wide and 1 ¾” tall. The walls are 4 mm and the base is 10mm. Sanded to 600 grit, wet sanded with 600 grit and BLO, Beale Buffed with Tripoli, White Diamond and Carnauba Wax.
    Continued
    Attached Thumbnails Attached Thumbnails Bowl3Front.jpg   Bowl3Top.jpg   Bowl3Bottom.jpg
    Aug 2008
    NorCal, USA
    495
    Three Bowls #2
    I turned the second bowl at home. I wanted to use some of the techniques I learned in class, and wanted to do a different shape than I have done. This is a mystery wood I got out of a grab box of wood at the Reno Woodcraft. It was labeled Maple Burl, but I know it is not Mable. I was thinking Walnut, but it seems a little red for Walnut. It is 3 ¼” wide, 1 ¾” tall with walls 3 mm thick and base 8 mm thick. Sanded to 600 grit, wet sanded with 600 grit and Boiled Linseed Oil, Beale Buffed with Tripoli, White Diamond and Carnauba Wax.
    Continued
    Attached Thumbnails Attached Thumbnails Bowl4Front.jpg   Bowl4Top.jpg   Bowl4Bottom.jpg
    Aug 2008
    NorCal, USA
    495
    Three Bowls #3
    The last bowl was turned for the class. It was turned from Black Walnut that had been rough turned wet in a previous class, and allowed to dry. The bowl is 6 ¼ wide, walls are 3 mm and the base is 10 mm. Sanded to 600 grit, rubbed with Boiled Linseed Oil, Beale Buffed with Tripoli, White Diamond and Carnauba Wax.. Don’t have the slightest idea how that dimple got into the base. It’s not from the tail stock as I turned the tennon off with a donut chuck.
    I sure love the look and feel of Black Walnut, my favorite wood to turn so far.
    Critique and comments are welcomed.
    Attached Thumbnails Attached Thumbnails Bowl5side.jpg   Bowl5Top.jpg   Bowl5Bottom.jpg
    Bowl #1: Oh yeah! Very nice figure, and you did a good job of showing it off.
    Bowl #2: That's some more pretty wood, whatever the species is. It might be maple...I've seen some maple burl that was nearly that dark. I prefer the form of the other two bowls, but you still did a fine job on this one.
    Bowl# 3: Nice classic form, and pretty wood to go along with it.
    Three pitches, three swings, and three hits.
    10,606
    Real impressive Chuck !!
    I hope my first bowl at the class I'm taking at Rockler this Saturday comes out have as nice as yours.
    3,132
    Chuck that's 3 great looking bowls. I guess i'm more into the classic look as i really like the 3rd one.
    Goodland, Kansas
    4,834
    All great looking bowls. Really nice forms and finish.
    Bernie W.
    17,475
    ok chuck yu passed the application test now sign up for the swap we got started very nice bowls and the figure in the orphaned blank is great..
    4,553
    Nice work Chuck ya done good now back to work on the ORGAN
    Jay
    Jul 2007
    Des Moines, IA
    854
    Chuck, nicely done.
  1. A few bowls...
    By Mark Cothren in forum Lathe Project Showcase
    Last Post: 12-10-2008, 03:57 PM
  2. and...................more bowls!
    By Barry Stratton in forum Lathe Project Showcase
    Last Post: 03-17-2008, 02:00 PM
  3. ......and more bowls.......
    Last Post: 02-15-2008, 11:32 PM
  4. A Few Bowls
    By Wayne Bower in forum Lathe Project Showcase
    Last Post: 02-13-2008, 02:43 AM
  5. ....more bowls..........
    Last Post: 02-04-2008, 08:49 PM
