Results 1 to 10 of 15
Thread: Does this make sense?
    Inside the Beltway
    2,666
    Hey, folks,
    Back at it, and I need to make some frame and panel doors using rail and stile bits. Now, I *do* have set up blocks for the bits, and they get me "fairly" close, but as we've learned to our pain, "fairly" ain't gonna cut it when Doorlink's involved!
    So, I thought of getting one of these for my router lift: http://www.wixey.com/remote/index.html
    That way, when I get a good set up, I could just jot down the setting, to the thousandth of an inch (close enough, even for Doorlink!) and just return to the setting anytime I need to.
    But then I thought to myself "Hmmm... we're told never to bottom out a bit in a router collet." Why that is, I have no idea, but I always bottom out the bit, pull it up a little, and tighten. The problem is that "pull it up a little" would destroy any possibility of repeatable accuracy! I'd have to zero out the thing every time I changed bits, and previous settings would be useless!
    Any thoughts on this subject?
    Bill
    Bill as long as you zero the bit to the top of the table then move to your set point the setting will be repeteable
    Sacramento, CA
    1,367
    Yep - what Don said.
    I have one of those on my Amazon wish list hoping the in-laws will buy it for me
    Jason Beam
    Sacramento, CA
    17,475
    bill drop a rubber o ring in the bottom of your collet,to maintain the space and the unformity you are looking for the fit on a rail and stile bit set is generally right on yu just need to set one up first then match it with the next bit..do the cope cuts first then the stiles and the sides of the rail. takes the tear out away better the differnce yu may get can be sanded smooth elimnating the doorlink problem
    I agree with what Don said about set up. I use one of these and get very repeatable results.
    I'm with Larry, Rubber O ring!
    Glenn
    Did you make that or buy it?
    パトリック
    daiku woodworking
    ^deshi^
    neoshed
    Quote Originally Posted by patrick anderson View Post
    Glenn
    That looks like a Harbor freight DRO and a home made holder for it. Looks good and functional.
    5,322
    Plans for it were in one of the magazines a couple years ago. You're spot-on in your observation, btw. The DRO's go for about six bucks (on sale) at HF.
    I've made two of them - one for Tablesaw, and one for router table - using Baltic Birch. They work very well.
    3,134
    Jim
    Do you have HF's Item number for this tool?
  1. A curious sense of acquisitiveness
    By Ryan Mooney in forum Off Topic Discussion
    Last Post: 04-21-2016, 03:35 AM
  2. A sense of accomplishment!
    By John Pollman in forum Off Topic Discussion
    Last Post: 10-05-2012, 07:53 PM
  3. Who said God doesn't have a sense of humor!!??!
    By Jonathan Shively in forum Off Topic Discussion
    Last Post: 11-20-2011, 02:41 PM
  4. My wife has a sense of humor
    Last Post: 09-16-2010, 05:29 PM
  5. Does it have sense ?
    By Alfredo Rodriguez Garcia in forum Off Topic Discussion
    Last Post: 01-13-2008, 04:50 AM
