Results 1 to 7 of 7
Thread: Router bit usage question............
    Central CA
    797
    This is probably pretty basic for most of you but.....
    I have the Whiteside 6 bit general router bit set and I'm using the chamfer bit in my table mounted 7518. Is it okay to use the bit without the bearing on top?
    Thanks very much.
    Thanks, Mark.
    Custom Bonehead.
    My diet is working good. I'm down to needing just one chair now.
    "Just think how stupid the average person is, and then realize that half of them are even stupider!" --George Carlin
    15,811
    If you have it half buried in an auxiliary fence (piece of scrap clamped to the real fence) then yeah, you bet.
    Central CA
    797
    Hmmmm.....I want to take the bearing off. Is this okay?
    Thanks, Mark.
    Custom Bonehead.
    688
    Hey Mark,
    Its probably ok, but why do you want to take the bearing off?
    15,811
    Quote Originally Posted by Mark Rios View Post
    Yes....
    Central CA
    797
    Thanks very much.
    Thanks, Mark.
    Custom Bonehead.
    WNY, Buffalo Area
    873
    I would have to agree with Stuart, on using the bit with a fence.
    You could take the bearing off, but I wouldn't do that without having it half way in the fence on your router table.
    Without the bearing or fence, the bit may want to bury itself in the stock. Aside from destroying the piece that you are working on, it might be dangerous too. Depending on the bit, the bearing may sit on a small post. If the bit pulls into the stock, this small post doesn't have anything to cut it clearnace. This might result in a broken (and flying bit! ) and/or a broken collet.
    -Sean
    www.tinyurl.com/thewoodshoppe
  1. Replies: 13
    Last Post: 12-11-2015, 04:42 AM
  2. Plane usage on the lathe
    By Darren Wright in forum General Woodturning Q&A
    Last Post: 06-22-2014, 10:10 AM
  3. Tool usage guide....
    By Gerald Schacht in forum Off Topic Discussion
    Last Post: 06-29-2008, 01:17 AM
  4. Shaper usage
    By Travis Porter in forum General Woodworking Q&A
    Last Post: 01-10-2007, 12:59 PM
