Results 1 to 3 of 3
Thread: Whiteside router bits
    I just bought from Amazon the Whiteside router bit #2710. It has two bearings, one on top and one on the bottom, thus ideal for template work. My question is that I can't find the bit in the Whiteside catalog. Also has anybody used this bit and what has been their experience with it.
    Thanks, DKT
    14,586
    here is the place that i get bits from,, and they have it listed.. here is the link to it but i dont have that one so cant help you in the reveiw of it
    http://www.routerbits.com/cgi-router...9766_19160+150
    6,819
    I have the 7/8" diameter version (2715?). Whiteside are my favorite bits with Freud running a close second. Holbren is my preferred supplier for price and low shipping costs. For flush or pattern trimming, I use the largest diameter that will follow the curve as this gives me the smoothest result. I think you will be quite happy running this bit at speeds above 20k rpm. One of the joys of a top and bottom bearing bit is that you can almost always route 'downhill' avoiding tearout ;-)
    Be excellent to each other. - Rufus
    Stand firm for what you believe in until, and unless, logic and experience prove you wrong.
