Results 1 to 10 of 15
Thread: Spraying in cold?
    Floydada, Tx
    1,941
    Spraying in cold?
    OK, rigth now my shop migth as well be in the middle of the feild. What is the lowest temp to spray plain lacquer and what temp is the lowest for pigmented lacquer?
    i`ve sprayed nitrocellouse at and slightly below freezing....dry time is slightly longer.
    Floydada, Tx
    1,941
    Thanks Tod. Maybe I will build a temp warm room to help it dry faster.
    Apr 2009
    Outside the beltway
    5,261
    If it's under 50 I don't like to spary so I turn the heat on.
    Me too with the cold spraying (although you can, it may fail) Heat the shop but also remember that the project is sitting in the cold and takes a while to warm up as well, In such a situation I would suggest taking the project, and the finishing supplies into the house the night before you plan to do the deed. Next morning warm the shop, then take the project and supplies out and (if need be, turn off the heat source) then spray. Warm products, warm project, warm surroundings make for safer finishing conditions.
    After the finish you can turn the heat back on. If using open flame or radiant gas heater, you need to have the air clear of spraying fumes before re-lighting. I use a Propane Radiant heater to knock the chill off my garage when I use it as a shop. Does a great job.
    Apr 2009
    Outside the beltway
    5,261
    The problem with cold spraying is the wood will not allow the product [Lacquer} to bond, it will dry but will crack and alligator soon after.
    Catalunya
    4,632
    I do not know wether it is true or not but I heard that cold spraying may cause the lacquer to "fog" instead of drying clear
    Best regards,
    Toni
    Floydada, Tx
    1,941
    Thanks all. I will see about building a small area for keeping the temp up for a hour or two.
    Bill, there is no main heat source at this time. I am in a old pole barn where one door is missing and the roof is open I am lucky I can run one machine at a time if his wife isnt home. Will get pics tommrow.
    Apr 2009
    Outside the beltway
    5,261
    That to Toni
    Catalunya
    4,632
    Quote Originally Posted by Dave Hawksford View Post
    That to Toni
    żUh?
    Please explain
    Best regards,
    Toni
  1. spraying shellac
    By Rich Soby in forum Finishing School
    Last Post: 06-10-2014, 07:22 AM
  2. great product for spraying
    Last Post: 09-01-2012, 01:53 PM
  3. Spraying Lacquer or Poly
    Last Post: 03-02-2012, 02:40 AM
  4. Larry how is the lacquer spraying
    Last Post: 02-24-2011, 06:46 PM
  5. lacquer spraying question.
    By Gerald Schacht in forum Finishing School
    Last Post: 06-21-2008, 09:17 PM
