Results 1 to 6 of 6
Thread: Stopper Buffing Handle
    Aug 2008
    NorCal, USA
    495
    I have a three wheel buffing system and made this handle to buff stoppers so I don’t lose them across the garage. The handle is 12 1’2” long with 3/8" x 16 tpi (the size of Ruth Niles’ threaded studs) all thread threaded into the end about 3”, and exposed ¾”. I turned a tennon ¾” long by 15 mm thick to accept a ¾” piece of ½” schedule 40 PVC which saves the handle when buffing the bottom of the stopper.
    Attached Thumbnails Attached Thumbnails Stopper buffing handle adj.JPG   Stopper handle end adj.JPG
    Well...that takes all the fun and excitement away, Chuck.
    Looks like a great idea. Not sure I understand the reason for the PVC, though. If the buffer hits that handle, seems like all it'd do would be shine up the handle. Am I missing something? Either way, I still like the idea, and will log it away for the future.
    Aug 2008
    NorCal, USA
    495
    Vaughn,
    I have cut into the wood on a couple of items that I buffed, probably over aggressive with the white diamond compound, and my thought was that, over a period of time, the end of the handle would get worn away, hence – the PVC collar. It may be overkill, but if my hunch is right, a ¾ chunk of PVC is a lot cheaper than a chunk of Maple. I tend to over think things anyway. By the way, the OD of the PVC is the same OD of Ruth Niles’ #301 stopper.
    Jul 2007
    DSM, IA
    5,719
    Great idea Chuck, thanks for sharing!
    My Website
    Goodland, Kansas
    4,834
    Great idea and thank you for sharing.
    Bernie W.
    Quote Originally Posted by Chuck Rodekohr View Post
    Vaughn,
    I have cut into the wood on a couple of items that I buffed, probably over aggressive with the white diamond compound...
    Yeah, if you're removing wood with the buffer, I'd say you're being WAY over aggressive, especially if it's with the white diamond, which is finer than the tripoli compound. But now I see your reasons for adding the PVC collar.
  1. Buffing Question
    Last Post: 11-08-2010, 01:58 PM
  2. Buffing
    Last Post: 10-19-2010, 10:55 AM
  3. buffing set up
    By Stephen Bellinger in forum General Woodturning Q&A
    Last Post: 09-21-2010, 01:27 AM
  4. Wax Buffing ??
    Last Post: 01-30-2009, 08:43 PM
  5. Buffing........how do you do it...??
    By Stuart Ablett in forum General Woodturning Q&A
    Last Post: 11-21-2007, 06:57 PM
