Results 1 to 4 of 4
Thread: Compressor Reminder
    13,364
    Compressor Reminder
    While I was cleaning up my shop, I found this kit I had put together when I was playing around with electronic stuff. Basically just a little box with a switch and a couple of led's that blink. Simple thing.
    Re-purposed it to use it as a reminder for my compressor on off switch. I have a bad habit of sometimes leaving the compressor plugged in and turned on. If I don't close the main air valve, the leak in my overhead spring loaded compressor hose has a leak that can cause the compressor to go on and off at times.
    So I just stuck this to the compressor. When I turn on the compressor, I turn on the lights. It serves as a reminder that I have the compressor turned on...
    I think this is the kit I originally used for this.
    I thought you were going to remind everyone to open the drain and drain off any water..
    13,364
    That reminds me, I should check mine! What with the humidity around here getting up into the 20% range lately!
    I know the feeling..I checked mine a few years ago and didn't get anything out maybe this time..
  1. Reminder for Don
    By Ryan Mooney in forum Off Topic Discussion
    Last Post: 12-29-2014, 05:32 AM
  2. Reminder
    By Roy Millsaps in forum Off Topic Discussion
    Last Post: 09-11-2014, 02:31 AM
  3. Just a Reminder - FYI
    Last Post: 11-06-2009, 06:34 PM
  4. Reminder for the new members!
    Last Post: 10-02-2009, 03:32 PM
  5. A reminder
    By Scott Donley in forum Off Topic Discussion
    Last Post: 12-20-2008, 11:24 PM
