Results 1 to 10 of 21
Thread: Help, can't get mu Mortice machine to cut
    Unhappy Help, can't get mu Mortice machine to cut
    I picked up a mortiser today, put it together and so far all it is is a glorified drill press. I set it up per the instructions but alas assoon as the square bit touchs the wood that as far as I can go..
    I know I'm doing something wrong but just can't firgure it out.
    Sep 2007
    Plainwell, Michigan
    4,857
    sounds like the drill bit is set to far up into the chisel. It should be down I think around 1/16" to create clearance between them.
    the book says 3/32-7/32 I've trive it up and down.
    does the chisel move at all
    Dec 2008
    falcon heights, minnesota
    5,609
    don, i usually set the bit around 1/16-1/8" below the end of the chisel. works like a charm for me, oak, mahogany, even borg pine.
    benedictione omnes bene
    www.burroviejowoodworking.com
    Sep 2007
    Plainwell, Michigan
    4,857
    When I used Larrys the instructions said to slide the chisle up to about hte thickness of a nickle (can use one as a thickness guage) from being all the way up and tighten the set for the chisle. then push the drill bit tight to the chisle and tighten. then losen the chistle and push it the rest of the way up and tighten. That setting worked for red oak.
    Dec 2008
    5,609
    sounds familiar, but i don't use a nickel (my wife raids my change pockets). i usually set the chisel all the way up, then lower the drill bit so that the wings are about 1/8" below the tips of the chisel.
    Sep 2007
    Plainwell, Michigan
    4,857
    Got that,tried 5 pennies once, a little to big a gap Yep either way will work, just got to find the gap that works
    OK I'll play with it. I just tried it on some pine and it worked. First time was white OAK. I gotta figure this thing out b4 I tackle the maple.
    Dec 2008
    5,609
    i had my doubts at first too don, and i was surprised that it went through the white oak that used for my furniture (once i got it through my head that it works by hogging out the waste just before it squares the hole). i always call it the machine that does the most unnatural act in woodworking, it drills a square hole. my dad had to see me do it 3 times before i finally broke down and told him how it's done...
    10,604
    Until you said that it worked on pine I was thinking that your depth gauge as screwed up.
    Never had the problem with mine. I set it up according to the book and it works in all substrates.
  1. Turn a machine into a variable speed machine ie drill or lathe etc.
    Last Post: 05-29-2014, 08:20 PM
  2. The Do Nothing Machine
    Last Post: 03-29-2014, 05:43 PM
  3. FS: Sorby Boxwood Handled Mortice Chisels
    By Jim Galvin in forum Old Ads
    Last Post: 06-26-2009, 12:24 PM
  4. Dovetail Mortice & Tennon
    Last Post: 07-07-2008, 01:14 AM
  5. Fixing a mitered mortice and tenon joint
    By Alex Reid in forum General Woodworking Q&A
    Last Post: 06-06-2007, 12:34 AM
