Results 1 to 9 of 9
Thread: New (to me) #7 Jointer
    13,360
    So, Got it in the mail today. Seems like it's been a workhorse in a past life!
    The question I have is about sharpening the blade. This looks like it has a bit of camber to it ? Slightly rounded at the edges.
    Is that normal for a jointer?
    Can anyone point me to a good tutorial on sharpening a plane iron with a slight camber?
    Thanks!
    Yorktown, Virginia
    5,011
    Brent,
    Derek Cohen's site is always helpful to me. The link is for putting camber on a bevel up plane but includes instructions for a bevel down also. Just soak up the knowledge and modify for your #7.
    http://www.inthewoodshop.com/Woodwor...aneBlades.html
    17,471
    welcome to the plane world and cant add anything to what derek can tellya
    Oct 2009
    Bradford, Vermont
    425
    I don't think I'd tolerate a camber on a jointer iron - it'd be impossible to get a well-jointed surface. A jointer's leavings SHOULD be entirely flat, something suitable for a rubbed joint. A cambered iron can't do that - at best it'd leave a concave surface behind, and two concave surface don't join to each other very well - especially if you're using a glue that's not known for its gap-filling properties.
    Now, for a SCRUB plane, yeah - that'd make sense. Even for a smoother. Not for a jointer, though.
    -- Tim --
    13,360
    Tim, That's kind of what I thought. I'm pretty new to handplanes. I mean, sure I've got a couple and I use them for the common uses, trimming, chamfering, but nothing serious.
    I kind of just bought this plane on a whim, thinking it'd be nice to have a big snow show. If I was really going to joint something, I'd most likely use my powered jointer.
    But now that I've got it, and I see how it was setup, I'm wondering if somebody didn't use it as a big long smoother?
    I'll have to see how I want to use it, but it sure is a big ole son of a gun..
    Oct 2009
    Bradford, Vermont
    425
    Feels good in the hand, though, doesn't it? Years ago a fella gave me a #8 with one corner chipped. Lemme tell ya, after a while that gets to feeling like a LOT of iron to be pushing around. There've been times I've wished for a #7 instead.
    -- Tim --
    13,360
    It's definitely a big ole chunk of Iron!
    I turned an old shelf into a project cart this last weekend. It seems so handy, I think I'm going to make a laminated 2x4 top and use the new plane to flatten it. Seems like a good way to get the tool tuned up, learn how to use it, and create a useful piece of shop furniture in the process!
    5,320
    Pretty much what Tim said...
    I sharpen mine straight across, and just knock maybe 1/64" off the corners at an angle. You want as straight and flat a cut as possible from your jointing plane - that's why it's called a jointer.
    13,360
    Sounds like a plan. I'm going to do a little tune up on it them and see what I can do.
  1. New jointer....maybe?
    Last Post: 11-01-2009, 03:29 AM
  2. Jointer
    By randy street in forum New Tools
    Last Post: 08-30-2008, 02:10 PM
  3. New/old jointer
    By Frank Fusco in forum Old Iron
    Last Post: 06-06-2008, 01:34 PM
  4. No Big Jointer?
    Last Post: 03-30-2008, 08:41 PM
  5. Which jointer?
    Last Post: 08-07-2007, 09:29 PM
