detail work on the legs
Today was a bit slow going. First I made a pair of jigs for tapering the legs. The legs are 3/4" thick where they join the pedestal, and taper to 1/2" at the floor. The first jig raises the leg 1/8" at the tip. The second raises the leg 1/4" at the tip. Note the prominent label, as I am prone to really dumb sequencing errors. They go into my planer and just miss touching at the dovetail end.
This is a pair of spare part legs that I ran thru the jigs, showing the taper.
After the planer, I wanted to smooth the sides of the legs with a hand plane, to remove any machine marks, and leave a nicer surface. The jigs worked just fine to hold the piece.
Next, with rasp, spokeshave, scraper and sandpaper, I rounded the corners and fitted the legs. I wanted the legs to flow into the pedestal. This took alot of time, and a good deal of scraping and hand sanding. Pencil marks on the top of the leg show the curve I seek. It should match the curve of the pedestal.
The results - compare the legs now with earlier, they are rounded, tapered, refined and flow into the pedestal. I sanded them to 320 grit, in preparation for some finish, which will be shellac.
I started on the tabletops. They will be 17 1/2 - 18" round. These boards are cherry, from one tree, are mostly quartersawn, and hopefully will be well matched. The rough stock was 7/8", and the tops will be 1/2" thick. Here they are jointed and planed, ready to select and combine for the best appearance. More to come another day....
