Results 1 to 1 of 1
Thread: Some More Projects and More Finish Questions
    Palm Springs, Ca
    1,169
    I had the day free and spent most of it finishing or working on projects I had laying around. My problem and question relates to the Mesquite wood that i turn. I have applied oil both AO and BLO the the turnings - 3 coats usually and when they dry i get a light white haze to them. The haze will disappear after i apply Laquer (which is what i usually do post oil and letting them sit for days to weeks).
    Pictures below and explanation of where i am in the finish process.
    Picture 1 - Mesquite with 2 coats of BLO (BLO with 1/3 Mineral Spirits) Now day 2 of drying with light white haze
    Picture 2 - Mesquite with 2 coats of BLO as above - No haze showing yet
    Picture 3 - Mesquite - Oil soaked in BLO/Turp/Gloss Varnish x 12 days and dried for 2 weeks - getting first coat of Laquer in the picture.
    This bowl came out very dark and looks better than the pic shows - im sure due to extended soaking - However, it was buffed post oil soak and it looked like crap so it was wiped down with mineral spirits and first coat of laquer was applied as i said above.
    Picture 4 - 2 coats of AO and first coat of laquer applied - looks good so far
    Picture 5 - Mesquite Vessel with 1 coat BLO and 2 of AO - haze showing and still drying tomm will be day 5
    Picture 6 - Mesquite Vessel same as above
    Picture 7 - Mesquite with Analine dye and 6 coats of Laquer - no problems
    Picture 8 - Logs the Gardner dropped off - not sure if ill cut for firewood or turn some (Its Pine - exact species unknown)
    My big issue is with all the above is what is the best way to finish Mesquite - it does have pores which i will usually wet sand with the oils up to 400 or 500 grit and does help to fill them but still the finishes so far i think lack in something...............
    Any ideas gang ??????????
    Attached Thumbnails Attached Thumbnails Mesquite-1.jpg   Mesquite-2.jpg   Mesquite-3.jpg   Mesquite-4.jpg   Mesquite 5.jpg
  1. Finish Work and some questions ?
    By Dan Mosley in forum Lathe Project Showcase
    Last Post: 01-30-2010, 02:30 PM
  2. Questions before I apply finish
    By Tom Baugues in forum Turning Tool Questions and Show & Tell
    Last Post: 10-29-2009, 09:38 AM
  3. Maple Pet Urn Finish Questions
    By Bobby Dietz in forum Flatwork Project Showcase
    Last Post: 07-29-2009, 03:59 AM
  4. Replies: 1
  5. To finish or not to finish - That's the question!
    By Bruce Shiverdecker in forum General Woodturning Q&A
    Last Post: 01-10-2007, 04:22 AM
