Results 1 to 10 of 21
Thread: Sturdy Table for tractor implements
    Sep 2009
    Midlands of South Carolina
    271
    Now that the tractor shed is up, I need to start storing stuff.
    I have two attachments for the front end loader. I have 3 (soon to be 4) rear attachments for the tractor.
    In order to save space, I was thinking that I could store the FEL bucket and grapple on a table, and put a couple of rear attachments under them. The front end loader can hook up to the skid steer implements and drop them on the table without issue - I think
    The table would need to be real sturdy - to hold around 1000 pounds fully loaded, and get banged around somewhat. 12 ft long, maybe 4 ft deep and 3-4 ft high.
    Is this a bad idea?
    Any good table design suggestions? I am thinking 4x4 legs and 2x4 edgewise on top - similar to workbench, but space between the 2x4s so dirt can fall thru.
    5,323
    Good idea - might need a center set of legs to minimize sagging.
    Should be rugged enough.
    Oct 2009
    Bradford, Vermont
    425
    If you've got power down on the loader, the table's gonna' need to carry a LOT more weight than you think! Even if it's gravity-down, I'd add quite a bit of safety factor to the table - ever try to pick up a bucket that's all tangled in whatever machinery HAD been stored under it? Ain't level any more, it's hard to hook up to...
    How about a steel rack for the bucket & grapple?
    -- Tim --
    North West Indiana
    6,101
    Rick, is this so you can store two pieces on the same piece of real estate (ie: stacking them without them actually touching each other? If so, hanging from the rafters, a set of chains for the front end loader. I find I don't take mine off. The rear (3 pt.) implements, I drop in a row outside in one pasture. The more hassle to put away, the less it will be put away correctly each time needed.
    Jon
    Sep 2009
    271
    Here is a clunky diagram of what I am thinking. This table would sit in the back of the shed (12 ft wide bay).
    Usually, only one item on the table except when switching from one to the other.
    Tim - yes, Power down, but I would let it settle with gravity (draft) - I would need real sturdy.
    Steel table is plan B
    No table is plan C (actually it's current)
    Jonathan - I have been keeping them outside, but sometimes they sit a while and get covered with leaves, hide snakes, and fire ants seem to like setting up housekeeping. I really hate fire ants - specially if I am focused on getting things hooked up and not paying a lot of attention to where I am standing ...I like snakes, as long as I see them first
    11,834
    I think it is an idea doomed for failure. Farm stuff gets bumped and clunked so much nothing is ever 'exactly' right.
    If you do try, use steel, lots of it.
    Dec 2008
    falcon heights, minnesota
    5,610
    rick, here is an idea based on my workbenches. the long front and back cross members, and the center front to back cross member would have to be notched where they intersect. the whole thing is put together with 2x6's and sheet rock screws.
    benedictione omnes bene
    www.burroviejowoodworking.com
    Oct 2009
    Bradford, Vermont
    425
    My vote is still with the steel rack or table... and with legs MUCH futher apart than you now imagine... unless you can accurately get tractor attachments into much smaller spaces than I can without a whole lot of concentration. Me, I'd bump the heck out of something one way or another, someday... and fold a leg underneath & spill everything & have a big pile of steel to pick up before I could get back to doing what I was doing.
    -- Tim --
    i`m in the leave `em on the ground camp.
    hydraulics-n-gravity work well together.......if ya add wood to the mix it usually looses......if ya build "stout" racks out of steel it`ll cost ya dearly.....and if ya knock one over there goes the wall of your new building
    Oct 2007
    Nova Scotia, 45N 64W
    1,247
    Rick
    With all due respect to Tod, I'm in the "everything under cover and put away" crowd.
    You need some surplus warehouse pallet racking. This stuff is commonly used for this very purpose among many of my farmer-clients in my real job.
    The racking comes in different weights, I suggest a corollary to the Larry Rule: Buy it Stout. Check the yellow pages.
    Set your racking up at the back of one of your bays, level and plumb, on a good broad base, maybe some surplus railway ties or treated 8x8s (no concrete floor in your shed, as I recall). Tie the rack into the building. Get yourself a set of quick-attach forklift forks for the tractor for lifting stuff up.
    Finally, put the implements each on their own solid hardwood pallet (the country's full of them) and tie them on with a ratchet strap.
    You're in business!
    Be safe!
    Peter
  1. Well hey thar I got a tractor too
    By Bart Leetch in forum Off Topic Discussion
    Last Post: 06-11-2011, 06:20 PM
  2. Luv thy tractor
    Last Post: 03-22-2011, 04:02 PM
  3. old garden tractor help!!
    Last Post: 11-16-2007, 06:09 PM
  4. Tractor photos
    By Jeff Horton in forum Off Topic Discussion
    Last Post: 06-05-2007, 09:16 PM
