Results 1 to 8 of 8
Thread: Face to Face Glue-ups Without Sliding
    There was some discussion here about flat face to flat face glue ups and the slip-n-slide that can bother us. Probably more than one of us has used or at least heard of this method.
    I'm building up a small pedestal base like the unfinished and unglued one stacked up in the background. I pre-sand the surfaces that will be hard to reach later like the small chamfers and recesses.
    I drive in very small nails and snip them off with a pair of side-cutters leaving just a nib poking up to grab the next piece. Whether you use 2 or 3 or 5 will depend on the size of your surface. You may notice the darkness on the end grain left from my wiping with mineral spirits to check for sanding marks and assure I've got the surface I am after.
    I clamp a piece of scrap in the vise to use as a reference surface to align the backs in this case, spread the glue with my customized Rockler gift card glue spreader and stack them up.
    The little spikes on the top of each layer (except the final top surface of course) keeps things from slipping around while I tighten down a couple of cauls.
    Gently now, don't crush the little fella.
    13,353
    Nice !
    15,806
    Yep, that is a trick I've used a few times, and it sure works well!
    30,002
    I was gonna say "slick trick" but then I realized that would be wrong. Great tip, Glenn.
    Oct 2009
    Bradford, Vermont
    425
    Word of caution - if ya use this technique to build up a blank destined for the lathe... be aware of those little nails in there & the heartache they can cause when you turn down to 'em.
    If you're building up blanks for turning, drop a couple grains of coarse table salt or playground sand in each corner instead of using nails. That's granular enough to grab, and small enough that it won't penetrate your femoral artery when it comes back out.
    -- Tim --
    If you know anyone who sandblasts, coarse crystal silica will work pretty well and present a minimal impact.
    Woodstock, Ontario, Canada
    719
    When gluing two pieces of wood together where I use C clamps I put the 1st clamp on a corner , edge or end, then another at the other end on the edge or corner. By pinching the work there it doesn't slide. Then add more clamps , then reposition the two you have at the edge. Works 90% of the time to control the sliding around Of course this wouldn't work in this situation for accurate assembly.
    hobby woodworking since 1972
    Oct 2007
    Schenectady, NY
    912
    I've done what Tim & Glenn suggested and it works. Use the sand or salt sparingly-only a couple of grains in a couple of spots works fine.
    Don Orr
    Woodturners make the World go ROUND
  1. Well.....Slap my face!
    By Ken Fitzgerald in forum General Woodturning Q&A
    Last Post: 10-22-2014, 03:28 PM
  2. Face frame
    Last Post: 09-23-2014, 07:40 PM
  3. CA glue & Face plates
    By Ned Bulken in forum Turning Tool Questions and Show & Tell
    Last Post: 04-16-2008, 03:29 PM
  4. A Plate around the face
    By Robert Schaubhut in forum Jigs and Fixtures
    Last Post: 05-19-2007, 03:34 AM
  5. face frames
    By Doug Sinjem in forum General Woodworking Q&A
    Last Post: 12-27-2006, 02:44 AM
