Results 1 to 10 of 16
Thread: Making a Bowl Steady....
    15,815
    I'm making a bowl steady, something like this...........
    I've got most of the parts already made, but the wheels I don't have. They show what looks like inline skate wheels, which are not rock hard, but have some "give" to them, I guess that would be best, but would hard nylon wheels be a no-no?
    Indiana
    224
    From everything I read, inline skate wheels work very well. I'm still trying to figure out how to use the old bicycle wheels for my bowl steady.
    15,815
    I figure something with a bit of give would be good.
    Well I'm off the the Dungeon for some cutting and drilling, do some welding tomorrow, heck, I might even get some sleep tonight!
    Kutztown PA
    252
    Stu, I think you would be happier with something that is going to give a little. It is no fun trying to remove the lines made by compressed wood. Let us know how it works out for you. I have a conventional steady for the Poolewood, but it will not fit the Vega, so if this works out well for you, I may have to look into one myself.
    Bill Grumbine
    www.wonderfulwood.com
    Steve Clardy Guest
    I have that oneway steady.
    I had a small issue with one of the wheels, which they promptly replaced.
    Wonder if you could just buy the wheels from oneway?
    I could also check to see if I could get them. I bought the steady through Packard Woodworks.
    30,231
    Quote Originally Posted by Steve Clardy View Post
    I suspect he can get roller blade wheels for less money than the Oneway wheels, and from everything I've seen, the rollerblade wheels work like a champ.
    A steady is also one of the items on my to-do (or to-get) list.
    Steve Clardy Guest
    I've already got a email sent to Packards on the wheels.
    15,815
    I'm looking for a good used pair of skates cheap, but now I have to go out and get them girls, so we are going to a store that has this kind of thing, I hope I can find some "Replacement" type wheels...?
    Any way, what happened in the Dungeon so far......
    Here I am tapping holes to be used to hold stuff on the thick plate that will hold the wheels and adjusters
    This is the basic set up, the thick plate at the top on the bar slides up and down
    The angle iron at the base will get a slot in it, and that will allow the steady to slide in and out away from the headstock.
    Next I drilled a bunch of holes on my toy drill press.
    It is really important to lay the holes out in a straight line and to space them right. Here I was using a 12 mm bolt, so a 12.5 mm hole was called for, I drilled small holes first, at a 13 mm interval and then the big holes.
    Once all the holes were drilled, I needed to connect the dots and this was done with my jigsaw, and a steel cutting blade, you HAVE to go slow, the slowest speed the saw can be set at, and be VERY careful about the blade moving up and down, no side to side movement, or you WILL break blades DAMHIKT!!
    To start the cut, you have to hit it at an angle, then turn the saw to cut straight.
    Slow and steady is the key
    I cut the whole slot without breaking one blade, and the blade still has lots of life left in it. Lots of guys overlook their jigsaw for metal working, I don't, it works well.
    Now the fun part... Bastard file, chalk, wire brush and sweat makes a smooth groove.
    When you are doing this, the size of the large drill bit comes into play. I could see the sides of the holes, and they gave me a gauge to go by, once the side of the hole just disappeared, the slot was the right size. If you use a lot of small holes around the edge of the grove, this is much harder to do, that is keep a straight slot.
    All nice and smooth now, as good as a CNC, nope, but good enough!
    Cont.....
    15,815
    OK, I cut out some mock up adjusters and wheels......
    I think you can see how this will work.
    The visegrips are holding everything in place while I figure out how this will work
    I think it will work fine, I see the adjusters will have to be a bit longer for the piece that holds the wheels, and will be very dependent on the size of the wheels...........
    That's it for now, hope you enjoyed the adventure so far, now I got to go find me some wheels!
    15,815
    Caution LOADS of pics!!!!!!!!!!
    OK, I had an OK day in the Dungeon, I ended up with a very successful failure
    Yep, in the end the bowl steady is going to still need some work, but I'm actually VERY pleased with it, even though, as it sits, it does not work worth a hoot
    Let me explain....
    First, I had a bear of a time getting them in-line skate wheels. I ended up buying a cheap pair of the in-line skates, lucked out, found a store with one adult set left, usually about $50 for the skates, but the box had been opened, and was not in good shape, the skates were a size 10 (fairly big in Japan) and the were the last set, so they were marked down to 1880 yen (about $15.75 US). I needed two wheels, now I have eight!
    I also kept the adjustable strap things, and there were two bolts that held on the brake stopper things, they are the same as the axles in the wheels, so keep them too.
    I next drilled out the patterns of the wheel holders and then cut them out with the jigsaw and filed ground them smooth.
    The results, here it is all mocked up ready to go
    More pics at a different angle
    OK, the welding is done
    More pics
    Now when I put it to use, the problem was soon apparent, the angle iron on the base, that goes from the ways to the bowl steady is way too flexible, it wobbles and bucks like all get out.
    Tried adjusting it up, down in out etc, but there is just too much flex.
    I'm going to try a thick piece of wood under the angle iron, see if that helps, but I need t nice thick plate of steel, about 1/22 or more, like the Oneway bowl steady is.
    Steve, you said you had one, how thick is the steel on it?
    ............cont
  1. My Homemade Bowl Steady
    Last Post: 04-02-2013, 11:01 PM
  2. Where to Place Arms of Bowl Steady
    Last Post: 03-14-2013, 09:33 AM
  3. Layout of Arms for 4 Arm Bowl Steady?
    Last Post: 03-12-2013, 08:52 PM
  4. More about a way of life than bowl making...
    By Bill Satko in forum Off Topic Discussion
    Last Post: 10-14-2012, 01:17 AM
  5. Making a Bowl With A Router
    By Dan Mooney in forum Hot Deals
    Last Post: 10-16-2010, 02:22 PM
Tags for this Thread
