Results 1 to 10 of 25
Thread: Guess how long this took.
    Oct 2009
    Dennison, MN
    512
    I hate building these. I don't do them often enough to get good at it, so I spend a bulk of my time bashing my head against the wall trying to make all of the angles work out. Not including the finishing, (cause I don't do that), I've got about 20hrs in it.
    I hadn't done a curved raised panel like that in a long time either. Forgot how terrifying those little fella's are going through the panel raiser.
    13,360
    That looks fantastic! I can't believe you only have 20 hours in it!
    Looks fantastic, that will really liven up someone's kitchen
    Twenty hours is a lot of work, but boy, I'd spend that much time just trying to figure it out!
    Pics of the installation would be great!
    Oct 2009
    Dennison, MN
    512
    No joke, at least 5 hours of that 20 is scratching my head. I ended up building a model of it so I could measure all of the legs. I couldn't wrap my head around getting all of the lengths.
    It goes with a kitchen, Laundry, and master bath remodel that I should be installing Wensday, so I should have pics by the end of the week.
    Shop full of cabinets:
    13,360
    Hmmm,
    I think we need to create some conversions here.
    Obviously 1 KB hour = 5 BD hours....
    13,442
    Great work Karl! What kind of wood is it? Maple?
    Oct 2009
    Bradford, Vermont
    425
    Quote Originally Posted by Karl Brogger View Post
    Boy, I GUESS - especially the one that goes UPGRAIN into the cutter!
    I do hope you're temporarily attaching those to a larger board to give 'em some inertia & not getting your fingers that close to big spinning carbide... not even taking into consideration the fact that on the 2nd edge there's nearly no support left.
    -- Tim --
    30,014
    May have taken some major head-scratching, but it sure came out looking nice. I'm looking forward to seeing the whole installation.
    I know that I would still be head scratching and not working...
    Magnificent work!!
    paul
    Remember the tea kettle - it is always up to its neck in hot water, yet it
    still sings!
    Oct 2009
    Dennison, MN
    512
    Quote Originally Posted by Tim Hofstetter View Post
    I did all four sides while they were still square. The end grain I used a T-square. Going with the grain isn't too bad and I just did that by pushing it through. I've got a really sweet insert cutter head that the cutters do not stick past the edge of. I'd still get mauled by the three bolts on the edge, but nothing like getting butchered by the actual cutters.
    After all four edges have been run, I mark out the backside with a template that I make off of just marking once the frame is loosely assembled, and adding whatever I need to make it go into the groove.
    I did screw it to a piece of 1/2" baltic birch to cut the cove on the curved portion though. First one I ran through by hand........ correction, tried to run through by hand. It exploded. Not really but it dug in and wasn't usable. Actually, I think I made 5 of those panels. The next two came out perfect, but there was very little panel left, so I had to recut them and make them larger than what was actually needed, then trim a 1/4" off of each edge so there was something left of the raised part.
  1. Replies: 1
    Last Post: 09-19-2014, 04:50 PM
  2. Guess what it is...
    Last Post: 09-12-2013, 01:43 PM
  3. I guess I had to wait too long.
    By Jim O'Dell in forum New Tools
    Last Post: 12-23-2009, 11:04 PM
  4. I guess!
    By Jim Suzda in forum Welcome and Introductions
    Last Post: 02-18-2008, 06:05 PM
  5. Purpleheart: How long, O! lord, How Long?
    Last Post: 02-28-2007, 03:38 PM
