Results 1 to 10 of 14
Thread: Help finding source for specific hinges
    Fredericksburg, VA
    161
    I am in the process of putting together a few wooden photo albums, and want to use a specific type of hinge. The hinge uses "pins" that are inserted through holes drilled in the album's binding, sorta like in the picture below...
    The actual arm of the hinge shouldn't protrude as far out as the example, but hopefully you get the idea.
    I appreciate any help you might be able to help in finding a source!
    - Keith
    "Listen, here's the thing. If you can't spot the sucker in the first half hour at the table, then you ARE the sucker. "
    17,474
    try highland hardware or maybe van dykes restorers store ...
    Oct 2009
    Dennison, MN
    512
    Van Dykes is my first inclination as well. If you buy alot of hardware, they do have wholesale accounts as well, you need a tax ID number though.
    Nov 2008
    outside of Toronto, Ont
    183
    Oct 2009
    Bradford, Vermont
    425
    It seems to me... that I've seen that sort of male-female threaded-pin set in a stationery store or a bookstore someplace. There was a special name for 'em, but I don't remember what it was.
    Once you find a supply of THOSE, the battle's half over - then it's down to finding a hinge you can readily modify to accept those threaded coupling things.
    -- Tim --
    17,474
    ok tim has got me thinkun here,, really it hurts sometimes... try mc master & carr for the pins then like tim says look for modifyable hinges next.. mc master and carr have mulitudes of hardware stuff..
    10,604
    Maybe a scrapbooking forum
    13,361
    If you've got a craft store like 'Michaels' around, might be worth a shot.
    Independence, Kentucky
    1,355
    Source for specific hardware
    Keith the bolts that you are searching for are called sex bolts and Mc Master Carr carries them
    Chuck
    Oct 2009
    Bradford, Vermont
    425
    Quote Originally Posted by Charles Hans View Post
    Chuck
    That's IT! Sex bolts EXACTLY! Thank you, Chuck!
    -- Tim --
  1. small smooth steel pins - help finding source?
    By Ryan Mooney in forum Off Topic Discussion
    Last Post: 04-25-2014, 08:23 PM
  2. Source for Light duty narrow brass plated hinges
    Last Post: 03-21-2014, 10:38 PM
  3. Gender-Specific Driving Etiquette
    Last Post: 01-22-2010, 12:01 AM
  4. Also need help finding
    By Jim Burr in forum General Woodworking Q&A
    Last Post: 10-12-2008, 09:24 PM
  5. Help finding something
    By Chuck Beland in forum Off Topic Discussion
    Last Post: 10-08-2007, 03:29 PM
