Results 1 to 7 of 7
Thread: WoodRiver 4-Jaw Chuck
    I have a WoodRiver 1" x 8 TPI Self-Centering 4-Jaw Chuck(146801) from Woodcraft. I just got the #1 & #3 jaws for it.
    I'm happy with the chuck.
    However, I see many different types of jaws for other brands of chuck. Do any of these jaws fit the Wood River?
    Oct 2009
    Bradford, Vermont
    425
    VERY DOUBTFUL. Possible, but REALLY unlikely, except by chance. The reference grooves in the back and the screw hole positions are pretty manufacturer-specific.
    At some point, you'll want these:
    http://www.woodcraft.com/Product/202...aws-Chuck.aspx
    At that point, you'll have pretty much everything you could want for that chuck... the only likely exception being a set of blank jaw plates you can customize with MDF or plywood overjaws... and even those will see very limited use. In fact, a good 80% to 90% of your turning will probably be done with the stock #2 jaws & the Cole-style jaws (jumbos).
    -- Tim --
    lutefisk capitol, USA
    485
    I have the WoodRiver one and a couple Nova chucks and no, these are not interchangable. I got the WoodRiver on clearance with the Cole style jaws and left it set up for finishing off bowl bottoms. I don't know if One-Way or Vicmark will interchange but I am highly doubtful.
    Goodland, Kansas
    4,834
    No the oneway or Vicmarc jaws won't fit.
    Bernie W.
    May 2009
    Lafayette, Indiana
    2,380
    Joseph, I too bought the Woodriver chuck. It is the first chuck that I have ever owned and so far it has worked well. I did buy the set of flat jaws for it and am glad I did. I'm very new to using a chuck but I can already see where some of the other chucks would be a little easier to use if you could tighten them with one hand while holding the bowl with the other, however I have not had that much of a problem with it. I can usually get it tightened enough to hold on then tighten with both hands. I think this chuck will be very good for quite a while. I'm happy with it.
    Tom
    Thank you all!
    Yes, I am going to buy the Flat Jaw Chuck, so I'll have the whole set.
    I started this thread to determine what option are available.
    Presently, the WoodRiver chuck is more than adequate for me.
    Oct 2009
    Bradford, Vermont
    425
    It wouldn't hurt to pick up an extra set of jaw screws when you order that last set of jaws... just in case you mangle one of the original screws. I've seen it done.
    Also - on those aluminum flat jaws - do NOT overtighten the screws! SNUG is what you want, not clenched down till your puckerer is puckered tight. Tighten 'em too tight & the aluminum will gall against the screw & you'll have the devil's own time getting the screws back out next time you change jaws...
    DAMHIKT.
    -- Tim --
  1. stanley lie-nielsen woodriver number 1
    By John Daugherty in forum Neander Tool Questions and Show & Tell
    Last Post: 03-01-2015, 04:34 PM
  2. WoodRiver Low Angle Block Plane
    By Matt Hutchinson in forum Neander Woodworking Q&A
    Last Post: 03-08-2011, 05:20 PM
  3. Donut Chuck used in Scroll Chuck
    By Dawson Mossman in forum Turning Tool Questions and Show & Tell
    Last Post: 12-21-2009, 09:59 PM
  4. Will this Flat chuck fit any other brand chuck?
    By Tom Baugues in forum Turning Tool Questions and Show & Tell
    Last Post: 07-03-2009, 07:33 PM
  5. Titan Chuck vs G3 Chuck
    Last Post: 09-26-2007, 06:37 PM
