Results 1 to 10 of 11
Thread: Dining Table Finish Recommendation
    13,001
    Question Dining Table Finish Recommendation
    So just wondering if there are any recommendations for a finish for a largish dining room table.
    I don't really think I want anything glossy, I'd like for it to be pretty durable and stain resistant, easy to apply, and able to be applied in the cold weather.
    I can probably heat my shop up a bit on the really cold days to be able to apply a finish, and even during some parts of winter we have some decent stretches of days here in Reno.
    I was thinking of some sort of wiping varnish? Any recommendations would be very welcome!
    8,508
    I'd use the following.
    BLO
    Transfast or transtint dye to the color you want
    Old Masters Gel Varnish
    13,001
    Ahh, I guess I should have said that the color I'm going for is 'natural'. Looking for something to basically match our kitchen. The floors we'll put down and the darkness of the countertops provide the contrast, so I'm looking for a fairly light table.
    Thanks Don!
    Oct 2009
    Bradford, Vermont
    425
    Are you going for "maple white", or a sorta' "golden" maple? If you're shooting for true-to-color maple, your best bet will be either one of the non-yellowing water-based polyurethanes or a lacquer (yes, you can get a matte finish out of lacquer). If you're shooting for a golden color, an oil-based polyurethane is the ticket - that or WB poly or lacquer over shellac of the appropriate shade.
    Um... how much work are you willing to put into finishing this table top?
    One problem may arise - you NEED to keep the shop stabilized at temperature until the wood's reached both temperature equilibrium AND humidity equilibrium (which changes when you heat the air), THEN apply your finish. Ideally, you'd also "soak" the wood at temperature until the finish is fully cured.
    The wood will start to move when you warm it up, shrinking as it dries to the now-lower humidity that comes with warmer air. It'll move until it's matched the ambient humidity, then stop. Apply the finish too early you arrest that shrinking. When you bring the table into the house later, it'll slowly shrink more in the warmth of the house - and that extra shrinkage may cause ripples, wrinkles, & cracks in the finish. Really - hold it at temperature for a week, even if you have to put up a small temporary cardboard room around it to get'er done.
    I've hitchhiked (WOW what a mistake!) through Reno - it's dry, but your heated house is drier.
    -- Tim --
    11,766
    Brent i could not help myself. But are you already finished/
    13,001
    Quote Originally Posted by Tim Hofstetter View Post
    Thanks for the good advice Tim. I'm not necessarily going for a 'honey' maple. I don't plan on doing any staining, but if the finish darkens or yellows the wood a bit, that wouldn't bother me too much. Since this is basically going to be a daily use table, I don't want to go for too glossy of a finish.
    We actually keep the place pretty cool in the winter time, but definitely much warmer than the shop. I've probably got a few weeks where temperatures will let me get the glue up done. Once thats over, I'll have to figure out something else for the finishing.
    I'm very fortunate to have a very pragmatic and understanding wife. I'm sure I could re-arrange some of the furniture in the house and bring the table top inside for finishing.
    Right now I'd say I'm leaning towards a oil based poly, just because of the ease of application and durability, but then again, I don't really know that much about finishes...
    My answer would be Polyurethane, and lots of it. Gloss not Satin. Satin is loaded with light dispersers that mask the shine by misdirecting the light. Unfortunately it also begins to show cloudyness as you add coats and sometinmes looks hazy. I prefer a gloss finish followed by an oil rub to tone down the gloss to the sheene you prefer. After the finish is several days Hard. you can uses a soft cotton cloth and Mineral oil, spread the oil about and then sprinkle a small amount of Pumice begin rubbing the slurry all about (doesn't take long to tone down the shine. Wipe off the mix and polish to a luster, Add a coat of Paste wax and hand buff. This finish and texture will resist hot dishes, scratches, spilt liquids and alcohol. Wipes clean with a damp rag and if scratches should occur, you can re-rub down and polish.
    Rochester
    834
    I think you'll want something hard and impervious to moisture....poly or possibly Waterlox. Bill's idea to tone down the gloss by rubbing is good, but you can also use gloss on the undercoats and use just one coat of satin to reduce the hazy look it give with multiple coats.
    Got Wood?
    Sep 2007
    St. Louis, MO
    579
    Gloss has a higher solids content than satin or matt. If you go with poly, consider using gloss for the first few coats and applying the satin as the final coat.
    paulh
    Central NY State
    3,363
    Good advice given already, and I've little to add, except this - even if your good wife will allow you to apply a poly finish in your home, you might not want to. The off gassing and smell from curing poly is awful. One option might be to put a small portable electric heater under or close enough to the table top to stabilize the temperature well enough to cure in the shop.
  1. (Re)Finish for dining room table
    By Warren White in forum Finishing School
    Last Post: 08-06-2010, 06:12 PM
  2. Finish for white oak dining chairs
    By Dave Black in forum Finishing School
    Last Post: 12-17-2009, 10:55 AM
  3. dining table
    By Barry Richardson in forum Flatwork Project Showcase
    Last Post: 10-31-2009, 02:51 AM
  4. Dining table progress
    By Kirk Constable in forum Flatwork Project Showcase
    Last Post: 05-16-2009, 07:30 AM
  5. pool table/dining table input welcomed
    By Robert Schaubhut in forum Designs, Plans and Sketches
    Last Post: 05-22-2008, 03:31 AM
