Results 1 to 10 of 12
Thread: Breadboard problems
    Apr 2008
    Butte Montana which is 1/2 way between Purgatory and Heaven
    170
    Breadboard problems
    Made my first board (actually about 7 months ago) - since is was my first attempt I did a face grain for the experience. I Planed it, sanded it and it was a smooth as a babies bottom.
    Now several months later you can feel every seam or joint. Is this movement normal - or did I do something wrong.
    Jiggs Elphison
    810
    17,471
    hey john what glu do you use in the cab shop? and jiggs yu got a pic of your bread board..the term face grian has me puzzeled..
    I am wagering on normal wood movement. I mean if you were WAYYYY up north in Missoula, it would be real dry . A pic of the seams you are feeling would help but, expansion and contraction generally happen more across the grain than with it. Are the seams you are feeling where a board could hae gained or lost width?
    30,009
    Jiggs, I've seen the same thing happen with my cutting boards, and for the most part, I blame in on seasonal changes in the wood. I have noticed, though, that the boards I've glued up with Titebond II -- particularly end grain boards -- show the problem, but the ones that I've made with plastic resin glue (DAP Weldwood) don't.
    As John mentioned, I'd not worry much about it. If it becomes bad enough to bother you, a few minutes with some 400 or 600 grit sandpaper will work wonders.
    810
    Apr 2008
    170
    Breadboard problems
    Thank you all for answering - especially Vaughn, not wanting to slight anyone I consider him the Guru of Cutting Boards. Sorry Vaughn but it was your posts that prompted me to join this Forum.
    I just glued up my first end grain. It's going to be small, 1 1/4 x 11 x 12-
    I measured once and cut twice (from both ends) - I felt the smaller size would be easier to learn how to sand the end grain- now I have to figure what you mean by adding sacrificial boards so you can run them thru the planer.
    Larry you have asked me to show pictures a couple of times and some day I will, but I really don't want to embarrass myself. I'm 73 years old, legally blind and have only been at this for about 6 years have been trying to learn by reading and asking questions.
    Jiggs Elphison
    30,009
    Jiggs, hopefully this sketch will help explain the sacrificial boards for the planer. The two pieces at the ends are just scrap wood, with the face grain exposed to the planer knives. I make the scrap wood as thick as the end grain pieces are tall, then glue it on. When it's all planed, I trim off the sacrificial pieces on the tablesaw.
    Just be sure to take very light cuts with the planer.
    And thanks for the compliments. I'm flattered.
    17,471
    Quote Originally Posted by Jiggs Elphison View Post
    Jiggs Elphison
    well jiggs i wasnt asking to criticize i just wasnt gettin the picture ,,me being dense and when yu decide to show some pics go for it but i can guarntee yu that we all had and stil have ooops that we make and our first projects arent any better than yours.. we all started at the bottom and are still tryun to get better.
    5,320
    ...i can guarntee yu that we all had and stil have ooops that we make and our first projects arent any better than yours.. we all started at the bottom and are still tryun to get better.
    Ya know, I can't remember ever completing a project that didn't include at least one 'oops!'.
    I just try to creatively cover them up. Sometimes I'm sucessful at it. Other times...not so much.
  1. breadboard end
    By Chris Mire in forum General Woodworking Q&A
    Last Post: 07-13-2009, 02:53 PM
  2. help with doing breadboard ends
    By jim capozzi in forum General Woodworking Q&A
    Last Post: 04-07-2008, 04:29 PM
  3. Question on Breadboard Ends
    By Alex Reid in forum General Woodworking Q&A
    Last Post: 05-02-2007, 08:59 AM
  4. Wood for a Breadboard Question
    By Bob Wiggins in forum General Woodworking Q&A
    Last Post: 03-07-2007, 02:45 PM
