Results 1 to 10 of 11
Thread: Sharpen a Card Scraper
    Dec 2008
    Santa Claus, In
    4,779
    Ok, I have seen it in too many posts. How do you sharpen a card scraper? I picked some up today at Woodcraft, they look fine to my untrained eye.
    Oct 2009
    Bradford, Vermont
    425
    I hate to take the lazy man's way out... but I could type a LOT of words here, or I could just do this:
    http://www.popularwoodworking.com/ar...rpen_Scrapers/
    I skip the stone step, though... and I just use a stick burnisher - no fancy stuff.
    EDIT: This one provides better explanation, although it's aimed more at luthiers' scrapers:
    http://www.liutaiomottola.com/Tools/Scraper.htm
    -- Tim --
    Manistique, Michigan
    297
    Steve,
    There are a few videos on YouTube that show some ways to sharpen card scrapers.
    Rich (the Yooper)
    "To the world, you may be one person, but to one person, you may be the world."
    "Common sense is not so common."
    Great info guys, this is something that I need to be able to do better myself.
    Thanks guys!
    If you subscribe, Bob Van Dyke takes it to the next level here:
    http://www.finewoodworking.com/subsc....aspx?id=29750
    Bob goes well beyond what I do but has some of the best advice on scrapers I've heard; "I'm not gonna get it perfect but, you need to realize; that's OK. It'll work just fine".
    He also shows some good tips on methods of use here:
    http://www.finewoodworking.com/subsc....aspx?id=29751
    I jointed a block of hardwood square and cut a kerf in it to hold a mill file. I clamp the scraper in the vice and use the block as a guide to use the file. I do stone the faces and edges but a 600 grit diamond plate works for me. I happened to get the Veritas variable burnisher as a gift but the old car valve I used to use did as well ;-)
    13,360
    Once you get it sharp, Here's a a handy little holder that makes using it a little easier...
    Scraper Holder
    Dec 2008
    Santa Claus, In
    4,779
    Thanks guys, you came thru again.
    I watched the videos, read the articles and went down to the Dungeon for just a little while and had some success.............
    Still not as nice as I'd like the finish cut is not great, but better than I had been doing for sure.
    With the loupe I can really see that there is a burr there, but it is very jagged, so I think I have to go past the #1000 diamond stone I have and use the ceramic water stones, up to #10,000, that should do the trick in getting a smoother, sharper burr.
    Well, I had another go at it tonight, I followed the instructions in this >> LINK << that Tim posted, the "Ruler Trick" really helped things, thanks Tim.
ID:	39108 Click image for larger version.
    The shavings on the left I got tonight, the ones on the right are from last night, and the real proof was the surface of the wood was a lot smoother this time around!
    I still might invest in some of the LV jigs, they really do seem fool proof, and they are not expensive, so they might make good Christmas gifts etc.
    Thanks for the info guys, this was a really good experiment.
    Dec 2008
    Santa Claus, In
    4,779
    Stu, you are making me look bad. I haven't even started sharpening mine yet.
  1. Card Scraper Holder
    Last Post: 12-27-2012, 02:56 PM
  2. Card scraper question
    Last Post: 06-21-2012, 06:33 PM
  3. Sharpening a Card Scraper
    By Brent Dowell in forum General Woodworking Q&A
    Last Post: 06-27-2010, 08:36 PM
  4. Tutorial: Jig for card scraper prep
    By Bob Ross in forum Neander Woodworking Q&A
    Last Post: 01-22-2009, 05:00 AM
  5. What a card...scraper
    By Alex Reid in forum Neander Tool Questions and Show & Tell
    Last Post: 03-05-2007, 02:36 PM
