Results 1 to 10 of 27
Thread: vacumm help???
    17,472
    vacumm help???
    ok i was given this style of vacumm pump, only mine is missun the stuff that goes in the five holes..the top piece in this pic shows a chrome looking piece and a blck piece built withit???? any way its a precision scientific pump. i have tried to get info on this but no avail.. the model doesnt show up on mine the number for the cat. no is this 10021-23 and the
    S.N. is 23ak-11.. first of all i am tryun to find out if the cfm on this is enough for a bag and if so what size of bag. also i need to know what pieces i need to make this work for bag...help!!!!!! i have inserted a pic i found that looks like what i have Click image for larger version.
    thanks for what help you folks can offer
    Thomasville, GA
    5,994
    Larry,
    I found this reference for your pump. You could also email Joe Woodworker and see what he knows about it.
    Bill Arnold
    Oct 2009
    Bradford, Vermont
    425
    That's a heck of a gift - that model pump goes for about $400 used, where-is-as-is, on the street.
    It may be time to grab up wrenches & do some exploring. I'm pretty positive the silver tube stickin' out the top is an air outlet. There should be another tube or fitting near it that'd be the vacuum (air) inlet (the business end). That inlet should be filtered to keep dust & crud from your bag getting into the pump.
    Let's talk about the five holes you mention - can you show us a DiggiePic of 'em? About what size are they? Where are they located? Are they threaded? If they are, are they threaded for bolts or for pipe? If you turn the pump by hand (belt guard removed for the purpose) does air puff out any of 'em? Any develop suction that wants to suck the skin off your fingertip?
    Someplace is probably a drain hole for the pump's oil reservoir, and another place a filler cap & yet another place there's probably a sight glass. There's not a lot more that should be necessary for a pump like that - cover plates & the shaft that drives it & one air inlet & one air outlet.
    -- Tim --
    5,321
    This is as close as I could come. It's a slightly smaller unit, but looks like the same shell as yours.
    I did find a price for a new D150. $3275.00!!!!
    The d75 pulls 2.6 cfm, but I can't find a conversion for the 13.3Mpa into inches of mercury.
    Oct 2009
    Bradford, Vermont
    425
    Would you believe... that 13.3Mpa converts to 3927.48833 inches of mercury?
    -- Tim --
    Or enough vacuum to pull the crome off a bumper..
    17,472
    well here ya go tim.. the two top holes and the one big hole in frt are 1/2" pipe thread the bottom hole on the frt has a brass fiting in it??? the top back side has a small chrome threaded piece with a flat on it on one side// i tried to find a model and all i got is what i have gave you guys, but if its the one jim found its to small of cfm for any good bag use??? i was told i need at least 5cfm and preferably 7cfm...
Name:	tn_pump pics 001.jpg
Name:	tn_pump pics 002.jpg
Name:	tn_pump pics 003.jpg
    Larry,
    If yours is a D-150 then it would make sense that it will pull 2.6x2 or 5.2 cfm
    larry,
    a little dinky pump will pull vacuum on a big bag............it`ll just take a while to suck `er down.
    what you have will work fine for an 8' bag......if you want quicker holding power use a storage container, old propane jugs work fine or an old compressor tank.
    good ol` rebuildable american oilbath pump!
    Larry I have this pumphttp://www.woodcraft.com/Product/200...Vinyl-Bag.aspxfrom woodcraft ad have had no problems with using a bag 5' x 9' in size. I found if I use my shop vac in conjunction with the pump it just helps it to suck the bag down quicker. It looks like yours will do it without the assistance of the shop vac.
    By the way this pump is only rated at .8 cfm.
