Results 1 to 10 of 26
Thread: frame clamps
    17,471
    frame clamps
    what is the best clamp set up for a mitred frame? i know my idea wasnt it!!! i am not gettin intot he picture frame business but i got some tomake and can see where a mitered clamp setup can be useful.. so what are your choices and why?
    810
    5,320
    what is the best clamp set up for a mitred frame?...so what are your choices and why?
    Those plastic corners with quarter inch threaded rod connecting them do a fairly good job.
    So does the "merle" clamp from MLCS.
    I usually use these, though. I have two of them.
    These work pretty well, too. I have four of them.
    Or, you could just make up a good square of 3/4" plywood, drill a couple holes in it to hold the clamp heads, and use it on the inside of the corners, with a couple "F" clamps.
    All the methods work, but my preference is for the big frame vises. BTW, I picked mine up at a garage sale - $10 for both of them...
    Thomasville, GA
    5,992
    I have two Merle clamps from MLCS. They work fine but are a bit much for small frames.
    I have one of these sets that I use routinely for frames.
    I'm thinking about building a frame clamp like this one. I think it would be simple to build and easier to use for small to medium frames than the others.
    Bill Arnold
    Oct 2007
    Indianola, Ia about 12 miles south of Des Moines
    440
    I have two of the clampmate like Bill is thinking of making and one that uses the cornors and threaded rod. I use them to clamp baby caskets and use them top and bottom with the threaded rod clamp in the middle to hold the center tight.
    mostest-bestest i know of
    http://www.miterclamp.com/
    Oct 2007
    Nova Scotia, 45N 64W
    1,245
    Larry
    I was in the same spot last winter with a bunch of frames to make for a backlog of needlework and such around the house, but not interested in setting up a "framing shop".
    I bought the Lee Valley/Veritas speed clamp, similar to what others have recommended. Works great. Useful for little boxes and such too.
    Peter
    Bellingham
    2,449
    Woodpecker's solution, but not cheap.
    www.woodpeck.com/clampingmain.html
    Bellingham
    2,449
    Here is a new picture frame clamp from Rockler that I believe is based on a European design.
    http://www.rockler.com/product.cfm?page=19732
    I don't think there is a "Best" clamp, they are all good IF your miter cuts are accurate. If they are not 45 degrees then the rest is history.
    DKT
  1. Bed frame
    By Drew Watson in forum Flatwork Project Showcase
    Last Post: 10-30-2010, 02:13 PM
  2. G&G Pic Frame #2
    By glenn bradley in forum Flatwork Project Showcase
    Last Post: 08-15-2010, 01:32 PM
  3. New way to frame
    By Al killian in forum Carpentry and Construction
    Last Post: 08-23-2009, 05:15 PM
  4. Pole frame / Post Frame construction question
    By Lincoln Myers in forum Carpentry and Construction
    Last Post: 10-19-2007, 10:54 AM
  5. Frame that TV
    By Robert Schaubhut in forum Flatwork Project Showcase
    Last Post: 04-07-2007, 07:11 PM
