Results 1 to 9 of 9
Thread: Shawl Pin
    Oct 2007
    Harvey, Michigan
    687
    Shawl Pin
    Had a request from my wife, Colleen - who is an avid knitter - to turn a shawl pin. This is what I came up with and it is based loosely on a design of an old Viking cloak pin.
    Cherry, 3 1/2" outside diameter, 1 3/4" inside diameter x a tapered 5/16 thick. The pin portion - also Cherry - is 6 1/2" long x 1/8" diameter shaft. Sanded to 400 grit and will be finished with multiple coats of wipe on gloss poly - only one coat on at time of photo.
Name:	Shawl Pin v1.JPG
ID:	39160 Click image for larger version.
Name:	Shawl Pin v2.JPG
    Wife loves it!
    As always - your opinions, comments and critiques are welcomed!
    Thanks for looking!
    Steve
    Oct 2007
    Indianola, Ia about 12 miles south of Des Moines
    440
    I had never heard of a shawl pin, but it makes seance to me now. That is a very neat and it looks great.
    10,604
    Way cool !
    I would of guessed it was for a hair pin.
    May 2009
    Lufkin Texas
    105
    I have not seen one of those before, it looks great. Think I will try something like that for some Christmas presents. I hope my pin comes out half as nice as that one.
    30,019
    That's very cool, Steve. I'll bet Colleen loves it, and you should probably expect to make some more once her friends see it. I'm still trying to figure out how you held the ring.
    11,833
    Neat. Similar were used to hold blanket coats closed also. Hmmmm.....
    Oct 2007
    Harvey, Michigan
    687
    How to turn Shawl Ring
    Thanks everyone! Doesn't take much to turn - except for me the spindle portion took a while as I am not used to spindles!
    Vaughn - hope this clears up what I did:
    I had a block of dry Cherry that was approximately 4” square x 2” thick and used a forstner bit to drill a 1 ¼” hole about 3/8” deep for the #1 jaws of my Talon chuck to expand into.
    Turned the outside of the ring and finish sanded it. Then drilled about a 1/8” hole in the center of the block about ½” deep to use as a reference when reversing the ring. Used a parting tool to almost separate the ring from the block and finished the cut with a saw. When parting the ring – make sure that you start the cut so the ring block will be at least double the thickness of the finished ring dimension. You don’t want this to be a true ring form yet as the remaining center section will be used to align the ring.
    Face the block and make it flat / smooth. Cover the now smooth surface of the block with double sticky tape. I use 2” carpet tape cause I can get it at the local Menards. Here is where the 1/8” drilled hole comes in to play… turn the ring so that the finished surface will be against the tape, use the tailstock to center the ring and apply pressure until you are confident the ring will stick.
    At this point you can turn, shape and finish sand that side of the ring. Remember that it is tape holding the turning – so don’t get to aggressive! When finished, it only takes a little finger pressure to remove the ring from the tape!
    Hope that makes sense.
    Steve
    30,019
    Quote Originally Posted by Steve Schlumpf View Post
    ...Hope that makes sense.
    Poifectly. Thanks.
    Jul 2007
    Des Moines, IA
    854
    That is way cool, Steve. Consider the idea stolen by me.
