Results 1 to 5 of 5
Thread: question on laminated wood for bowl
    Nov 2007
    Salt Spring Island, BC Canada
    2,070
    Just wanted to know if there is anything to watch out for when turning laminated wood. I salvaged a chunk of 2x6 fir beam from an older school we were renoing earlier this year. I was going to use it for firewood but with the new lathe thought it might be fun to try to turn a bowl out of it. I have the outside turned and have cleaned it up with the scrapers now I will be starting the inside and hollowing it out. Just a little leary of how this stuff will react when I start working it down. anything to watch out for or should I just pass on this and use it for fire wood? All advice is appreciated.
    Attached Thumbnails Attached Thumbnails renfrew beam 002.JPG   Renfrew beam 2 003.JPG   Renfrew beam 2 004.JPG
    11,828
    Looks like you are doing fine. Pine is soft. But, if this were at the beginning, I would caution you about those knots in there. They could 'catch' you off guard. But, it seems, they didn't.
    Looks great so far, keep it going, but, make darn sure you have a stout enough tenon on the bottom of that thing, a really good stout tenon is NOT a waste of wood, busting off a bowl blank and having it careen around your workshop because the tenon was too skimpy, THAT is a waste of wood! DAMHIKT
    From the looks of it, your tenon looks stout enough, but what chuck and jaws are you using?
    Some jaws need a straight tenon, like you have, some need a dovetailed tenon.
    Oct 2009
    Bradford, Vermont
    425
    It looks like you're already past what I would have warned you about - that being a GOOD glue joint. Any glue starvation will blow the bowl in a hurry. If it's hangin' together at this point, ya got a good joint.
    -- Tim --
    Nov 2007
    2,070
    Thanks guys I was just concerned about getting into it. The jaws that I have Stu are (I feel)too small. I have the standard 50mm / 2 inch set and have ordered the 75mm / 3inch power grip jaw set that should be here by tomorrow. Still waiting for the stand though and am doing all this with it sitting on the saw horses. Yes being very careful. lol
  1. PV glue for bent laminated parts of furniture?
    Last Post: 03-21-2015, 08:15 AM
  2. Cutting Board with Laminated Inlay - Last Minute Christmas Request
    By glenn bradley in forum Flatwork Project Showcase
    Last Post: 12-09-2014, 12:43 PM
  3. Radiused Laminated Platform Bed/Dressers
    By mike marvel in forum Flatwork Project Showcase
    Last Post: 11-24-2011, 01:28 PM
  4. Wood Bowl - Unknown Wood
    Last Post: 10-02-2011, 02:23 PM
  5. Cutting Laminated Counter Top..***Final Stages***
    By Greg Cook in forum Carpentry and Construction
    Last Post: 03-11-2007, 04:30 AM
