Results 1 to 9 of 9
Thread: Screw Chucks
    Oct 2009
    Harrisburg, NC
    140
    Screw Chucks
    I started out turning everything with a spur drive and only changed to a faceplate when I ran into a very punky piece of wood. I have never thought about the screw until brought up in another recent post.
    I do have a screw drive which came with my chuck but have never used it.
    Other than punky wood, what other cautions should I be aware of? I watched Stu's video, on a larger piece of wood should the top be flattened so chuck jaws will sit flat on the wood?
    I want to give it a go next weekend so any suggestions/precautions will be appreciated.
    Mike
    All tyranny needs to gain a foothold is for people of good conscience to remain silent. Thomas Jefferson
    Cotswolds, UK
    629
    Quote Originally Posted by Mike Mills View Post
    .....on a larger piece of wood should the top be flattened so chuck jaws will sit flat on the wood?
    .....Mike
    Ideally yes, but if not possible to get full diameter register then insert wedges and secure them with Hot Melt to hold them against centrifugal forces while you turn chuck spigot/socket. Often pack one side of Chuck Jaw contact with coffee stirrer and hot melt for blanks from tapered stock.
    Chas. just a traveller on the road of time.
    Bits & Pieces Gallery
    My Web Site
    Oct 2009
    Bradford, Vermont
    425
    Depends on the screw chuck - if it's got a big fatty screw, there's no need for the stock to touch the body all the way around. It doesn't hurt, though... although it may be pretty hard to get it really seated, which is why most folks who use one don't go very far out of their way to flatten the side that'll get the screw.
    One really strong word of warning: do NOT - EVER - let your SLEEVE get caught in the dang thing!
    -- Tim --
    Oct 2009
    Harrisburg, NC
    140
    I have a Pinnacle (now wood something) from Woodcraft and just bought a SuperNova 2 when they had their sale (my $25 certicate won at my local woodturning club didn't hurt). The SN2 screw is much larger. I guess the CN2 is a fatty.
    The ones I have seen used in videos were all used with plates/platters and with dry wood (Raffan and David White). My concern is with green wood.
    Looking for a heads-up or DONT do this.
    Mike
    Cotswolds, UK
    629
    The SN2 is similar to my home made ones,
    Grips quite well in wet wood if drilled hole is kept to minimum diameter, if you can't move it by hand then it should be fine.
    My Web Site
    Oct 2009
    Harrisburg, NC
    140
    Thanks Chas and Tim.
    Thats one nice piece of work on that screw chuck Chas.
    The piece I am going to try next weekend is walnut about 11" diameter.
    I will at least remove the bark and then use the tail stock as Stu showed in his video. Should stay put with no problem.
    Mike
    Mike it will work, but you still got to be gentle, the screw is not that large. Also I find it a good idea to check the pressure on the tail stock frequently, as you turn the live center in the tail stock can work itself deeper into the wood, thus reducing the pressure on the tail stock, so just give the handle on the tail stock a crank every now and then.
    Aug 2008
    NorCal, USA
    495
    Mike, the SN2 instructions says not to exceed 600 rpm with the screw chuck. Use the tail stock as long as possible. Also, it seems like every time I screw the work piece off and on it loosens it up a bit and make the grip a little more sloppy.
    I use the screw chuck (and 60 live center) to turn a tenon and the bottom of the bowl, then chuck up the tenon to do the inside.
    Oct 2009
    Harrisburg, NC
    140
    Thanks for that headup Chuck.
    I round with a chain saw and start at 200 or so but then (as soon as possible) I crank it up to 800-1000. I'll keep my foot light on the petal with this one and try to maintain the posted speed limit.
    Mike
  1. Grizzly Chucks
    By Chuck Ellis in forum Turning Tool Questions and Show & Tell
    Last Post: 11-02-2011, 03:24 AM
  2. Low cost chucks?
    By Al killian in forum Turning Tool Questions and Show & Tell
    Last Post: 03-07-2011, 03:15 PM
  3. Questions on Chucks
    By Rob Keeble in forum Turning Tool Questions and Show & Tell
    Last Post: 06-18-2009, 03:05 PM
  4. New Vacuum Chucks
    Last Post: 03-28-2008, 09:23 PM
