Results 1 to 2 of 2
Thread: Handsaw handle altering
    I picked up this disston from my other post and wanted to know if anyone ever altered their older saw handle to what they wanted? I have stripped the handle bare and made the horns pointier... Now I was going to make the grip a bit softer and maybe add some more curves to it. Does anyone have any input on this.
    Beauty is only a light switch away!
    Forest Grove, Oregon USA
    290
    Hi Tom--yep, nothing I dislike more than uncomfy handles.
    While not directly related to what you are doing, the following link will take you to a small pictoral of shaping a new handle. Same applies within the limitations of present shape.
    http://wenzloffandsons.com/saws/kits/index.html
    Just go at it easy. Soften a little here and there. It helps to draw limit-lines before you begin. Also, it helps if there is a handle which you like in order to see the motions you may need to use the rasps/files to accomplish. Pictures, though, work in a pinch.
    Take care, Mike
    Wenzloff & Sons Sawmakers
  1. Pistol Grip Handsaw.
    By Rob Keeble in forum Neander Woodworking Q&A
    Last Post: 11-04-2013, 02:10 PM
  2. Need/ Want handsaw
    By Steve Southwood in forum Neander Woodworking Q&A
    Last Post: 05-23-2012, 03:07 PM
  3. Handsaw Totes
    By Roy Bauman in forum Neander Tool Questions and Show & Tell
    Last Post: 07-26-2011, 12:13 PM
  4. Perplexing Handsaw
    By Travis Johnson in forum Old Iron
    Last Post: 02-09-2008, 10:43 AM
  5. Old handsaw ID...?
    By Stuart Ablett in forum Neander Woodworking Q&A
    Last Post: 11-15-2006, 02:32 PM
