Results 1 to 10 of 13
Thread: Router Table Builders - Some help with DC
    9,077
    Thomasville, GA
    6,000
    Or, you can do it yourself with scrap. Like this:
    Bill Arnold
    5,175
    Hey Bill,
    What is the red between the elbows and the hose?
    Are the elbows a plumbing fitting of some sort, and if so, what size is everything?
    I got my Dust Deputy and wanted a tidier construction than hose from vac to cyclone.
    Thanks for your help.
    Oct 2009
    Bradford, Vermont
    425
    ...and if you tightly enclose your router like that... and you decide to do some routing without the DC turned on... gods help you. Can you say "hot like a firecracker"?
    -- Tim --
    Thomasville, GA
    6,000
    Hey Bill,
    Are the elbows a plumbing fitting of some sort, and if so, what size is everything? ...
    Carol,
    The red pieces are from a set of 2.5" dust collection parts a friend gave me. I have no idea where he got it, unfortunately. Mating components of 2.5" nominal size can be a bear at times, but the system he had included several types of adapters to go with the clear rigid pipe. The red parts between the hose and elbow is ridged on the hose side and smooth on the other.
    I finally found a reference for a 2.5" DC system like I described. Here it is.
    Bill Arnold
    Thomasville, GA
    6,000
    Quote Originally Posted by Tim Hofstetter View Post
    And you can explain why someone would choose to do something like that???
    Bill Arnold
    9,077
    I had a shop made box a few years back prior to building my cabinet. I was just hoping this commercial version would help out some folks who seem pensive about getting started on their router tables .
    Last edited by glenn bradley; 11-18-2009 at 01:27 PM. Reason: Correct CAPS, looked like I was yelling ;-)
    17,475
    as long as you are drawing air past the router, it should be cool enough to not be a problem.and like bill shows you want the side to converge to the out let hole and also have a n incline down to the back as well ..its better than flat like bill's and mine are.
    Thomasville, GA
    6,000
    ... ..its better than flat like bill's and mine are.
    Larry,
    I agree having a slope from all directions would be best but, as you can see in the photo of the inside, mine clears itself pretty well. That photo was taken after cutting over 300 half-blind dovetails in birch plywood. The air supply channel across the front of my containment box has enough of an offset that it directs air down the front panel and across the bottom of the box. Additional air is drawn through the router table/lift and keeps the router itself clean. Having said that, if I were to build another box, I'd probably include a sloped bottom.
    Then again, if it ain't broke, why try to fix it?
    Bill Arnold
    Nov 2007
    Salt Spring Island, BC Canada
    2,070
    Hi Glenn here is my set up. I am still working on finishing it off but the dc hook up works just great. It does clean out all the dust the spots showing were when I didn't turn the dc on. When the DC is on it is hard to lift the top as the suction is too strong.
    Attached Thumbnails Attached Thumbnails Router table 001.JPG   Router table 2 002.JPG   Router table set up 005.JPG
  1. Router table router recommendations - What are your experiences?
    By Matt Hutchinson in forum General Woodworking Q&A
    Last Post: 11-11-2012, 04:27 PM
  2. Ryobi tabletop router table and router combo
    Last Post: 12-05-2010, 02:02 AM
  3. Router Table Router and Lift
    Last Post: 10-08-2008, 06:21 AM
  4. Rockler Router Table and Router Startup Special
    Last Post: 08-22-2008, 02:56 PM
  5. Table Saw. Band Saw. Router Table. *** ALL SOLD ***
    By Rob Bodenschatz in forum Old Ads
    Last Post: 05-31-2007, 04:56 PM
