Results 1 to 10 of 24
Thread: Quick File Handles
    Quick File Handles
    I saw these quick file handles while reading Garrett Hack's book "Classic Hand Tools" and I thought they looked interesting.
    Basically, they are turned and then cut, so they are "Split" handles, with no ferrel.
    Here are all the tools I used, besides the lathe
ID:	39362 Click image for larger version.
    The piece of wood is 5 1/2" long, I mounted it on the lathe and then roughed it into a cylinder
    A little work with the skew and spindle gouge and I'm ready to part it off.
    Turned handle
    I check the length of the tang on the file, and mark the handle, so I know how deep to drill, you want to make sure the tang does not bottom out in the handle.
ID:	39367 Click image for larger version.
ID:	39368 Click image for larger version.
    Next up I take the live center out of the tail stock and the safety drive center out of the head stock and put the drill chuck in with the right sized drill. It turn the lathe down to about 250 RPM, center the drill bit on the hole left by the drive center and then hold onto the handle and turn on the lathe. Then turning the handle on the tail stock, I drill the file handle.
    I then cut two kerfs in the handle, at 90 degrees to each other........
    Cont...........
    here is the one I just finished.
    This one is made from Zelkova, or Japanese Elm, any hardwood would do I guess, has to have some spring in it.
    The time stamps on my pictures say 17 minutes elapsed, but that was with taking pics, I'm sure these can be turned in less than 10 minutes no problem.
    No finish, and if or maybe when they break, I'll make another one.
    Here are the three I did tonight, and one I did a while back, with a ferrel. The one with the ferrel is nice, for sure, but, it relies on the wood in the handle being crushed to hold the file, if it gets too crushed, then it is useless.
    I think I'll be making more of these, I'm now eying the cheap plastic handles that came on some of my cheap files
    13,357
    Is that a little slot you've cut down the middle to give it the 'spring'?
    North West Indiana
    6,097
    Wood being crushed due to the ferrel?? I am confused, could you please explain this statement?
    Did you glue the cut?
    Are you going to "wrap" the outside of the cut with maybe copper wire?
    Jon
    11,825
    That "crushed" statement has me bumfuzzled also.
    All look nice but I don't understand the need for the cuts.
    I have handled many files by just drilling a hole and pounding in the file tang until it is tight. Between the taper and square corners they seat and hold just fine.
    30,008
    ...I don't understand the need for the cuts.
    Ditto here.
    Nov 2008
    Ireland
    28
    What a relief! I read this earlier and thought I must be even stupiderer than I thought because I couldn't understand what holds the file in.
    I'm lost too Stu.
    Brendan
    Yes, the split springs around the file tang, hold the tang in place in the handle, but, if you remove the file from the handle, there is no wood that has been crushed, so the handle can be used on any other file and it will work just fine.
    If you have a hole in a piece of wood, and you "Pound" a file tang into it, then the hole will become shaped like the file's tang........right? The wood will get "Crushed" to conform to the shape of the tang that you are pounding into the hole in the wood, right
    If, during the use of the file, the tang works loose, you then have to pound it again, into the handle, and this will only work for a limited time until there is no more wood left to crush and conform to the tang on the file........ with me so far?
    Also, if you have a large file and you pound the tang into the handle and then, down the road, you replace that large file with a medium file, you cannot use the same handle, because the tang will be a smaller size, and will not be able to crush enough wood to get a grip.
    The beauty of the spring handles I've made is that I can change files in them and as they spring back, the file size don't matter.
    Clear as mud
    I'm curious, you guys have NEVER had a file handle work loose on a file and had to pound it back in place and then have it work loose again and find that pounding it did not work?
    This spring handle eliminates that problem.
    11,825
    Replace? Once together, it's like marriage forever.
    Need new handle? Make another, that's wat scrap is for.
    I would guess Frank, with the wild temp and humidity swings here, I have more trouble with the wood shrinking and expanding, as I have handles on files work loose all the time, and yes, I do know how to "Pound" a file tang into a hole
    Maybe I just use mine more vigorously than most
    Anywho, these spring handles work well, and they are faster to make than a handle with a ferrel, plus, I don't have to find and make a ferrel
    If the info is of no use, no worries, someone might find these handles of use, I did!
  1. File Handles---A Stroke of Genus (Gee Nuts)
    By Jim C Bradley in forum Off Topic Discussion
    Last Post: 02-11-2011, 02:23 AM
  2. How I file a Rip saw
    By Victor Skellett in forum Neander Tool Questions and Show & Tell
    Last Post: 08-21-2010, 11:00 PM
  3. Large PDF file
    By Aaron Beaver in forum Off Topic Discussion
    Last Post: 12-04-2008, 07:23 PM
  4. File type
    By Al killian in forum Off Topic Discussion
    Last Post: 03-06-2008, 02:00 AM
  5. Replies: 11
    Last Post: 11-26-2006, 04:25 PM
