Results 1 to 7 of 7
Thread: mobile base for the new bandsaw
    Dec 2008
    falcon heights, minnesota
    5,610
    this is the mobile base for the new bandsaw. it is 24" square, 3/4" plywood on a torsion box of 2x4's, with 2 in the middle, and doubled up on the ends. the casters are good for 200 lbs each. this should be able to handle that 165 pound bandsaw.
    benedictione omnes bene
    www.burroviejowoodworking.com
    13,361
    Looks similar to what I've done for my drill press. I'm still working on some cams to mount on the sides to gently lift it up enough to keep it from moving.
    So far, I'm thinking just some little levers that sit flat on the ground in the non-moveable position that when you rotate up, let the platform go back on the wheels. Should be easy enough, but I've been pretty lazy lately...
    Dec 2008
    5,610
    i've solved that problem brent, one of the casters is a locking caster.
    17,472
    table and chairs done yet brent??? huh huh
    13,361
    Who do you think I am? Allen Levine or something?
    12,258
    Tell him Brent
    Looks good and a lot cheaper than buying a steel mobile base too......Marshall
    Usually Busier than a Cat In A sand Box : Arkansas Red Wolf & Razorbacks Fan
  1. Mobile base on a TS?
    Last Post: 07-07-2011, 12:38 AM
  2. Mobile tablesaw base
    By Alan Bienlein in forum Carpentry and Construction
    Last Post: 02-27-2011, 09:45 PM
  3. Rockler Mobile Base - $29
    Last Post: 11-28-2007, 04:53 PM
  4. Delta mobile base
    By Rick Levine in forum Hot Deals
    Last Post: 09-23-2007, 04:12 PM
  5. Mobile base for table saw
    By Dennis Thompson in forum General Woodworking Q&A
    Last Post: 06-13-2007, 01:06 AM
