Results 1 to 6 of 6
Thread: What size band saw blade do you suggest?
    May 2009
    Lafayette, Indiana
    2,379
    I want to try my hand at some band saw boxes. What size blade and teeth should I look to get. I'm guessing about 1/4 inch and about 6 teeth per inch. Does this sound about right or should I have more teeth per inch?
    Tom
    Dec 2008
    falcon heights, minnesota
    5,604
    tom, check out my bandsaw thread in the new tools area. jim sent me a link to timberwolf. good people, they helped me select the blades for my new bandsaw.
    benedictione omnes bene
    www.burroviejowoodworking.com
    Oct 2009
    Bradford, Vermont
    425
    The tooth count needs to be selected based on the thickness of the wood you're cutting. Ideally, you should have three to four teeth in the wood at all times - less and you risk breaking off a tooth, more and the gullets between teeth will fill up too fast. So... if you're sawing 3/4" stock, you'll need between 4tpi and 6tpi.
    You can do work like this with as narrow a blade as 1/8"; that'll give you tight curves if the blade has a good set to it. A 1/4" blade with a wide set can turn pretty sharp curves, too, much wider than a 1/4" blade with very little set.
    How tight would you like to make those curves?
    -- Tim --
    17,470
    i use a 6 tooth 1/4" on my smalle Bsaw and have cut everything upto 2"white oak with it. and tim i made some nice tight curves threw your parts this spring those roads are fun to drive on at dusk with a decoy in frt
    Apr 2008
    Butte Montana which is 1/2 way between Purgatory and Heaven
    170
    Tom
    I use 1/8" - 1/4" & 3/16" blade from Timberwolf - I've really never paid any attention to the # of teeth, I just order the width.
    The 1/8 breaks easily, its real important to have the tension and guides set up as perfect as you can. Actually this is true for all widths , but especially the 1/8"
    The two books that help me are Sculpted Band Saw Boxes and Building Beautiful Boxes With Your Band Saw both by Lois Keener Ventura.
    To quote a line I read on the internet, "They should not be called Band Saw Boxes - They should be called sanding boxes" I can cut one out in 15 minutes - I'll spend a week or more sanding it.
    Please post your results
    Jiggs Elphison
    Oct 2009
    Bradford, Vermont
    425
    Quote Originally Posted by Jiggs Elphison View Post
    I LIKE that! Thanks, Jiggs!
    -- Tim --
  1. Band saw blade drift solved
    By Alan Bienlein in forum General Woodworking Q&A
    Last Post: 03-19-2012, 10:20 PM
  2. blade size and cutting rpm
    By keith Boutselis in forum General Woodworking Q&A
    Last Post: 03-05-2012, 05:33 PM
  3. Essential Band Saw Blade Set - Ellis Blades Received
    By Brent Dowell in forum General Woodworking Q&A
    Last Post: 09-08-2011, 07:51 PM
  4. prefered size of bandsaw blade?
    Last Post: 11-20-2010, 10:08 PM
  5. band saw blade advice sought
    By ken werner in forum New Tools
    Last Post: 05-05-2007, 12:39 PM
