Results 1 to 2 of 2
Thread: end grain boards
    Apr 2008
    Butte Montana which is 1/2 way between Purgatory and Heaven
    170
    end grain boards
    In my area i have a difficult time finding 5/4, 6/4 or thicker exotic stock, and when I do the bf cost is prohibited and/or the choices are extremely limited.
    Using 4/4 stock limits you to the patterns that you can create. So my question is what if or can you laminate 4/4 stock together to create thicker stock without running into problems when making end grain cutting boards.
    Jiggs Elphison
    Oct 2009
    Bradford, Vermont
    425
    You can definitely do that... the laminated pieces will move approximately like similar unlaminated pieces... and probably a little less, if care is taken to make up pieces with alternate growth ring direction.
    Like this:
    or this:
    -- Tim --
  1. End Grain Cutting Boards
    By Bill Arnold in forum Flatwork Project Showcase
    Last Post: 11-16-2014, 11:11 PM
  2. Tried my hand at a few end grain boards
    Last Post: 09-01-2013, 08:13 PM
  3. End Grain cutting boards... in progress
    By Ned Bulken in forum Flatwork Project Showcase
    Last Post: 12-29-2008, 08:19 PM
  4. End Grain Cutting boards with a different Twist
    By Dewayne Baker in forum Flatwork Project Showcase
    Last Post: 09-15-2008, 01:30 AM
  5. End Grain Cutting Boards are Flat Work
    By Mack Cameron in forum Flatwork Project Showcase
    Last Post: 11-19-2007, 06:55 AM
