Results 1 to 8 of 8
Thread: turning corian
    Jun 2009
    Live in Homeland, GA
    11
    turning corian
    I have not turned any corian myself yet. I know
    it makes beautiful pens. My question is what is the
    best glue to use. Seems like I read somewhere that you
    should lightly sand surface before applying glue.
    Does anyone know for sure?
    Thanks, Sandra in GA.
    Oct 2009
    Bradford, Vermont
    425
    CA glue works just fine - the glue Corian "fabricators" use is a two-part methacrylate, which is closely related. The roughness of the surface isn't terribly important - not as important as getting a good fit and getting as much of the surface "wet" with the glue as possible.
    I've turned some Corian pens - they're definitely distinct.
    -- Tim --
    11,828
    I have information from a member of SMC that is considered the 'guru' of Corian. He has a particular brand of CA that he says works best. (He also sells it.) He says to simply clamp the pieces together and dribble the CA on the seam and it will work it's way down and hold.
    Didn't work for me but that's what the guru says.
    I gave away a box of Corian because I didn't like turning it. Wood for me, 99.999% of the time.
    I've never made a Corian pen, however I have turned several different projects using it. Tough turning w/o carbide, spend a good deal of time sharpening... use a steaper angle when you grind your edges.
    Jun 2009
    11
    turning corian
    Thanks everyone. I appreciate the help.
    I'm guessing it's like acrylic as far as
    sanding should be with wet paper.
    Will let you know how it turns out.
    Sandra
    Oct 2009
    Bradford, Vermont
    425
    Actually... Corian IS acrylic. Some of the other solid-surface materials are polyester, which is slightly more fragile.
    By the way, it laminates up nicely to make larger-diameter pen blanks. The seams, while visible on close examination, are "unobtrusive".
    Another (sort of) interesting pen material is the blue-green plastic sewer pipe. It looks VERY MUCH like veinless turquoise. Very interesting for one or two pens, but it gets boring in a hurry.
    -- Tim --
    Having played with corian I might add that the pieces have a smooth top surface and a grainy underside, when you laminate them be sure to face the top to top surface so there is less seam visible.
    As for the Guru saying to clamp and the CA will seep into the seam... Maybe he is doing something he is not telling you about, but such procedure has never worked for me. It works when you adhere Plexiglass using acetone, but not with Corian (at least in my experience)
    A good friend is a Solid Surface Specialist and works exclusively with Corain and Similar products, Gives me loads of scrap and I in return make him trinkets and fancy goodies... I will ask him of their procedures to laminate.
    As for the lightly sand... I do ... Well at least I use green Scotchbrites to scuff the surface before glueing
    Central Illinois
    936
    I've turned about 500 pens with corian and wood combo, for the Freedom Pen Program.
    I use thick CA. Just put it on one side and and slide the two pieces back and forth to fully coat them, then clamp them together. Let sit about 10 minutes before drilling. Never had a failure.
    Bruce
    Bruce Shiverdecker - Retired Starving Artist ( No longer a Part timer at Woodcraft, Peoria, Il.)
    "The great thing about turning is that all you have to do is remove what's not needed and you have something beautiful. Nature does the hard part!"
  1. Corian is Nasty
    Last Post: 01-09-2014, 11:36 PM
  2. Left over corian
    Last Post: 07-10-2011, 05:37 PM
  3. Milling Corian countertops
    By Tom Niemi in forum General Woodworking Q&A
    Last Post: 07-15-2010, 04:15 PM
  4. Working Corian?
    By Joseph Shaul in forum General Woodworking Q&A
    Last Post: 06-20-2010, 01:03 PM
  5. Getting small pieces of Corian
    By Aaron Beaver in forum General Woodworking Q&A
    Last Post: 07-08-2007, 04:30 PM
