Results 1 to 10 of 18
Thread: Well, While We're Stealing From Mark Cothren...
    30,008
    Since Barry posted his Mark Cothren-inspired walnut bowl, I figured I should come clean, too. Jeff Bower got me thinking in this direction, and Mark's recent chunky bowls pushed me over the edge. So I'm admitting to blatantly stealing their ideas and running with it.
    This one is red eucalyptus with some neat curl. I'm guessing it's about 12" x 7" or so. (It's set up in a display 30 miles from here, and although I wrote down the dimensions, I can't find my notes.) The ends are rough cut (chainsaw and bandsaw). I shaped the bottom a bit to put it on a foot and raise the edges off the table, but I intentionally left the bottom rough. The finish is buffed Formby's Tung Oil Finish with more of Don Pencil's PL compound. (No buffing on the rough parts.) LOML likes this one a lot.
Name:	Bowl 077 - 02 800.jpg
ID:	39803 Click image for larger version.
Name:	Bowl 077 - 01 800.jpg
ID:	39804 Click image for larger version.
Name:	Bowl 077 - 04 800.jpg
ID:	39805 Click image for larger version.
Name:	Bowl 077 - 05 800.jpg
ID:	39806 Click image for larger version.
Name:	Bowl 077 - 03 800.jpg
    So...thanks for the inspiration Mark and Jeff. I did another one in jacaranda (it's not as nice as this one but I'll show it sooner or later), and will likely continue to run with the idea when the right blanks present themselves.
    Comments and critiques and finger pointing and giggling are all encouraged.
    BTW Jeff...now I've done a thick bowl, it's time for you to do a thin one.
    5,167
    OK. I like it. A Lot. But how did you hold it on the lathe? Rough bottom? Vacuum ruled out. Recess? Glue block? Filled screw holes?
    30,008
    I drilled a recess on the bottom with a 2 1/8" Forstner bit to start, then after I finished turning and sanding the top, I used the vacuum chuck to reverse it. Then I enlarged and embellished the recess a bit to remove the chuck marks, and whittled away at the wings (the rough-turned part) while leaving a raised ring around the recess to act as the foot.
    I did another similar piece that was too small to get a seal with my vacuum chuck, so I reversed it friction style and used the tailstock to hold it in place while I finished the bottom, leaving just a small nub to sand off at the end.
    Cornwall, England
    392
    You can also do it this way
    Pete
    Attached Thumbnails Attached Thumbnails Laburnum bowl (2).JPG   Laburnum bowl.JPG
    10,600
    Nice
    Mason Michigan
    455
    Vaughn,
    Excellent bowls!
    Pete,
    How did you hold that bowl? It is beautiful!
    "Small Change got rained on with his own 38"
    Tom Waits
    Jul 2007
    Des Moines, IA
    854
    Wow, Vaughn. That is a beauty. Thanks for sharing how you did it too.
    Pickles Gap, Arkansas
    271
    Looks good to me - love that wood! I'm gonna do me one like this, too. So right back atcha on the idea stealin'....
    If you have a pulse you have a purpose...
    Tellico Plains, Tennessee
    4,351
    Can I add mine... it's not as pretty as Vaughn's or Pete's.. this is a chuck of white oak or Champion Oak... not sure which.. came from my friend's tree "Isabella"...
    Attached Thumbnails Attached Thumbnails 10-834.JPG   10-834-5.JPG   10-834-6.JPG
    Chuck
    Tellico Plains, TN
    Cornwall, England
    392
    Turn yourself some scrap wood to a rough bowl shape that the piece can be dropped into. Glue chuck (hot glue) the piece into the bowl using wedges around it to secure it. Make sure it is in the right place so that it stands properly on the bark side. Use a hairdryer to warm up the glue when removing after finishing. You only need to turn the face or bowl side obviously. It won't work so well with wood that has loose bark. You people ue different woods so would knowbetter than me what would be suitable. This one is laburnum
    Pete
  1. My apologies to Mark Cothren...
    By Barry Stratton in forum Lathe Project Showcase
    Last Post: 12-02-2009, 01:59 PM
  2. A little something for Ned and Mark
    By Rennie Heuer in forum Off Topic Discussion
    Last Post: 02-10-2009, 09:33 PM
  3. Another Inked Piece from Mark Cothren
    By Vaughn McMillan in forum General Woodturning Q&A
    Last Post: 10-16-2007, 03:16 AM
