Results 1 to 9 of 9
Thread: Quick-release router table?
    Dec 2009
    Madison, WI
    206
    I recently bought myself a router, and am interested in using it as part of a router. However, most router tables permanently affix the router to the mounting plate. Does anyone know of a DIY quick-release system for one of these?
    Incidentally, having just spent way too much money on some fancy carbide hole saws, I'll be making the mounting plate myself out of a 1/4" thick piece of aluminum.
    30,019
    Joseph, I haven't seen a quick-release setup for a router plate, but on mine, there are only four screws holding the router to the plate. In about 2 minutes I can remove a router from the plate and install the factory baseplate. The baseplate itself is held on the router table with only friction. It lifts right off when necessary.
    Most folks just pick up a second fixed base. What type of router is it? Maybe someone has an extra they'd let go cheap(?).
    4,552
    The best solution is ------------ buy another Router, one is never enough anyway
    Dec 2009
    Madison, WI
    206
    An el-cheapo Bosch plunge router I picked up for $27 on eBay. From what I understand, most plunge routers require some sort of clamp to hold them in place so that they can be used with a table; removing this clamp is time consuming (if possible at all!)
    Nov 2009
    Midland Ontario Canada
    1
    How about a couple of toggle clamps with a pin to stop any rotational movement.
    Andrew
    It seems to me, Iv'e lived my life, A lot better than i think i have.
    4,552
    Quote Originally Posted by Andrew Yates View Post
    Andrew
    Vibration might make them come loose
    Simple, just leave it attached.
    Since I really don't use a router out of the table anymore, its always attached to the mounting plate. When I do have to use the router out of the table I just use it with the plate attached. It gives you a larger surface for the router to sit on and its less likely to tip. The mounting plate is just like a large baseplate.
    Northern Ohio near Sandusky
    32
    I got one of these for my Porter Cable 890 router. Can take it out of the router lift and back into it's base in less than 45 seconds.
    http://www.woodcraft.com/Product/200...R-Lift-FX.aspx
    JEFF
    If it don't fit get a bigger hammer
  1. Quick Router Bit Tray
    By Brent Dowell in forum Jigs and Fixtures
    Last Post: 03-15-2011, 10:10 PM
  2. quick table
    By Al killian in forum Flatwork Project Showcase
    Last Post: 04-28-2009, 12:17 AM
  3. Carter quick release bandsaw tensioner?
    By Wes Billups in forum New Tools
    Last Post: 01-08-2008, 05:10 PM
  4. Replies: 23
    Last Post: 09-28-2007, 06:03 PM
  5. Quick Review - Triton Plunge router *UPDATED*
    By Matt Dunlap in forum New Tools
    Last Post: 09-07-2007, 10:57 PM
