Results 1 to 7 of 7
Thread: Risers
    Sep 2007
    Bloomington MN USA
    268
    Risers
    I saw this in Wood Magazine issue 139. It looked interesting as I do a lot of assembly on my bench top. Also many times I need to lift up the cabinet onto 4x4s so as to get room for my clamps on both sides of the cabinet at the same time. It only took a couple of hours to build and it will be a very usefull item in the shop.
    You can clamp in many different spots on the risers, I made mine the same size as my bench so as to be able to clamp them easly to my bench top.
Name:	Risers with  clamps 1.JPG
    It is easy to use square ups in the corners as well.
Name:	Risers with clamps 2.JPG
    The artical called for useing lengths of plywood for the spacers, I chose to use up a lot of scrap plywood instead, gets ride of a lot of small pieces and does not change the way they work.
    If you make a mistake it was part of the original plan!
    Villa Park, CA
    1,407
    Good idea. One thing that occurred to me is the problem of gluing the project to the riser from glue squeeze out. Do you put something on the riser to keep glue from sticking to it?
    Mike
    Ancora imparo
    Thomasville, GA
    5,992
    The article in Wood Issue 193 doesn't mention a finish. I've used several coats of shellac or lacquer followed by Johnson's Wax to prevent glue problems on benchtops and jigs.
    Bill Arnold
    10,604
    I saw those too Bill and thought they would come in handy.
    Sep 2007
    Bloomington MN USA
    268
    Quote Originally Posted by Mike Henderson View Post
    Mike
    Mike I put a coat of BLO onthem and then 2 coats of clear shellac followed by several coats of Briwax. Squeeze out should be minimal as most of the time pieces are over hanging risers.
    Sep 2007
    Bloomington MN USA
    268
    Glad you mentioned about the finnish I had forgotten to put that in my post. Very good point,as you could end up with a cabinet/riser when finished.
    Catalunya
    4,632
    Thanks Ron.
    Just wrote down those on my "to do list"
    Best regards,
    Toni
  1. Spindle Sander Risers
    Last Post: 02-14-2014, 09:03 PM
