Results 1 to 10 of 17
Thread: Scraper plane blades
    Central PA
    638
    I want to make something like a stanley 112 scraper plane, My plan is to buy a replacement blade from veritas of Lie Nielson. Heres my question, Veritas has a thinner high carbon steel that comes standard on the plane and an optional 1/8th" A2 tool steel blade. The A2 blade is about 2x the price of the High carbon blade. Lie Nielsen's blade is 1/8th" A2 tool steel. Is the A2 is the "better" blade. Any thoughts about the blade thickness and A2 s high carbon steel, and anything in general about scrapers?
    Oct 2009
    Bradford, Vermont
    425
    A2 is an "air hardening" steel, which means its great benefit is that it'll hold its hardness up to a higher temperature than ordinary high-carbon steels like O1 and W1. In a scraper for wood, that's totally meaningless unless you use yours a WHOLE lot harder than I do. No scraper should ever see annealing temperatures as it's used, and since it's sharpened with a file (and optionally a hand stone) before burnishing with a hand burnisher, it'll never see annealing temperatures as it's maintained.
    A2 isn't harder or stronger or tougher than common high-carbon steel. In fact, quite ordinary W1 takes & holds a better edge. W1 can be hardened harder, O1 distorts less during hardening & tempering, and A1 has higher heat resistance. Choice of tool steel really comes down to a choice between one of those three (unless you reach for one of the exotics).
    As to thickness... a 1/8" scraper blade sure seems like overkill. That'd be a blade you certainly couldn't bow if you tried. If you're counting on making a scraper plane that bows the blade (as a #12 or #112 would), you'll want about the thinnest blade you could muster.
    -- Tim --
    30,014
    Insider tip: Dunno if you'd be interested, but I believe Dominic Greco will soon be listing a variety of scrapers and scraper plane blades for sale at good prices. Keep your eyes on the Commercial Post Zone for more info.
    17,472
    tim has it, i think your scraper term may be a low angle blade.. scrapers dont use thick blades..
    Central PA
    638
    Heres what I was looking at
    http://www.lie-nielsen.com/catalog.php?sku=112
    down the page a little bit it says about the blade and the thickness of it. I figured since lie nielsen was using that it should be good
    17,472
    Quote Originally Posted by Dave Black View Post
    your right its that thick.. learn something new everyday.. the old ones i had seen didnt have that thick of blade in the and they did flex as tim suggested.
    Central PA
    638
    I don't know which would be better, I assuming the thinker one would be better since lie nielsen is using that instead of the thin one.
    Oct 2009
    Bradford, Vermont
    425
    I don't think I like that - wouldn't an inflexible blade leave "curbs"? You'd have to radius the corners to prevent it. I like a flexible scraper MUCH better, since the act of flexing it rolls the corners up off the wood's surface and lends the rigidity it takes to prevent chattering.
    -- Tim --
    Sep 2007
    St. Louis, MO
    583
    I've always wondered about the thicker blades myself. I've been using the thinner ones and can't really see an advantage to the thicker steel. On a bench plane, thicker cutting irons do a great deal to eliminate chatter. On my scraper plane, the tall angle of attack generally takes care of the chatter. If it's a particularly difficult piece of wood, i find scraping in a different direction, or a variety of directions takes care of any chatter.
    On the other hand, every Veritas plane i own is very well engineered and built. I've grown to have a lot of faith in their design.
    I wish i could test drive one with the thicker blade.
    paulh
    Catalunya
    4,632
    I can't help much here but I believe that while a thin scraper held by hand allows you to work on a specific spot, with thick blades on a scraping plane force you to work on a more wide area to fix that same spot which eventually will give you a more uniformly flat surface, not to talk about less tiring in you fingers and hands.
    Best regards,
    Toni
  1. Sharpening plane blades
    By Julio Navarro in forum Carpentry and Construction
    Last Post: 03-20-2011, 10:53 PM
  2. Veritas Scraping Plane with 2 blades
    By ken werner in forum Old Ads
    Last Post: 10-24-2010, 03:33 AM
  3. Lie-Nielsen 112 large scraper plane - SOLD
    Last Post: 02-21-2009, 10:54 AM
  4. Veritas Scraper Plane Insert
    By Jason Beam in forum Neander Tool Questions and Show & Tell
    Last Post: 04-09-2007, 04:27 PM
