Results 1 to 10 of 11
Thread: Box in Figured Bubinga and Dichroic Glass
    Yorktown, Virginia
    5,022
    Made this one as a birthday gift for the Missus. 2-3/4" x 3-3/4" with a Dichroic glass inset. Two coats of Watco, buffed and renaissance waxed. I cheated and used a Forstner bit to do most of the hollowing. My daughter fuses the glass for me. That Bubinga is hard stuff.
    Attached Thumbnails Attached Thumbnails DSC05018-C.jpg   DSC05020-C.jpg   DSC05021-C.jpg
    5,175
    Lovely.
    But what is cheating by using a drill bit to drill a hole to waste the majority of the inside?
    Whatever works. And if you don't tell, who will know?
    That is really very nice. The Dichroic glass inset really is perfect for your box.
    Remember the tea kettle - it is always up to its neck in hot water, yet it
    still sings!
    That looks great, Ted. I really like the glass, too. Looks like it should have batteries, it's so "lit up" looking.
    I agree with Carol. I don't consider drilling to be cheating. It's using the tools at hand to your advantage. If the object is to remove wood to have a hollow box, then I don't think it matters if you use a Forstner bit or a snow shovel. It still ends up as a hollowed-out box. Whatever works to remove the wood.
    Yorktown, Virginia
    5,022
    Not so much 'cheating' in the traditional sense, but rather reducing the level of 'hand madeness'. I personally enjoy making the chips fly with a gouge or skew or some other hand held cutter, so in my mind if a Forstner in the lathe does the hollowing, I've cheated myself out of the experience of making the chips fly and building hand held cutting skills. (Not that I want to extend this fuzzy logic to sanding or any other activity where machines do a better and faster job ). My wife is a knitter and makes some beautiful things. There are also knitting machines that make beautiful things--but they are not hand made--so in her eyes the fact that the love isn't there diminishes the value of the final product. It's like the YouTube tour of the bowl making factory where a log rolls in one end and a bowl spits out the other end. It's a nice bowl, but it's just not the same as one made by someone who got a catch and knocked the tennon off and saved it by making a new tennon and adjusting the shape..blah blah..you know what I'm saying
    Goodland, Kansas
    4,834
    Beautiful Ted. I must say when I first started turning I did feel the same way you do. I would not use a forstner bit or any none turning tool for nothing. I felt like I was cheating. I would really feel guilty when I showed someone a box I had made but had drilled it instead of turned it. Now I really don't care. If I need to get a box done in short order out comes the bit. As my late granddad told me one time teaching me woodworking. Use the tools you have and he is right. I have a shop full of tools and if it will make the job easier especially as my age advances then I will use whatever. I try to keep things simple and easy now.
    Bernie W.
    Cornwall, England
    392
    Cheating is when you get a machine to do all the work for you. You still had to position the drill correctly etc etc etc. I do understand where you are coming from though. When re you going to get a pole lathe?
    As far as the box is concerned it is a beauty. I love combining materials like that. We see far too little of it IMHO and I am as guilty as anyone of not doing it. Boxes are my bete noir. I can count the successful ones I have made on one hand...without using all my fingers so Hats off to anyone who makes a good one like that
    pete
    11,833
    Box is very nice. I would like to see that Bubinga up close.
    Was the glass hard to turn?
    North Ogden, Utah
    348
    Wow, that wood and glass combination really looks good. The colors are great together.
    I have to disagree Vaughn. I just spent an hour using the snow shovel and it's not near as fun as using the other turning tools.
    Yorktown, Virginia
    5,022
    Thanks to all you fellow cheaters for the kind comments. Frank...believe it or not there are glass lathes
    http://www.littonengr.com/Products.cfm?pn=ART-121
  1. Waterfall Bubinga
    By Dan Mooney in forum General Woodworking Q&A
    Last Post: 05-24-2011, 01:23 PM
  2. Glass Real Flat Glass
    Last Post: 11-13-2009, 04:40 AM
  3. Bubinga Inlaid Box
    By Ron Sardo in forum Lathe Project Showcase
    Last Post: 02-27-2008, 07:11 AM
  4. Buffed Out the Bubinga
    Last Post: 07-23-2007, 02:44 PM
