Results 1 to 10 of 15
Thread: Joined at the hip....well the ring
    Cornwall, England
    392
    Asked to make a pir of my wedding goblets as a Christmas present for a couple who have been marrried for some timwe I decided to have a bit of fun while at it. The Goblets are 10" tall, 2! dia at the top and made of Bubinga. I was given a spindle by someone who was giving up turning through age and healtth.
    They both have the normal 2 captive rings on each stem but I made a third bigger one joining the two goblets together. As they will need to break it to use them I haven't finished it properly, just aquick coat of sealer to make it the same colour. The goblets are finished in Melamine to 'wine proof' and being a dark red should be OK for red wine as well which stains badly through anything.
    Goodland, Kansas
    4,834
    Those are beauties Pete. Really cool hooked together.
    Bernie W.
    North Ogden, Utah
    348
    Beautiful goblets and a neat idea to join them.
    Pete : this is very pretty , and what a great present too . They will love them ........
    Usually Busier than a Cat In A sand Box : Arkansas Red Wolf & Razorbacks Fan
    3,132
    Pete turn them up side down and you'll have two bells.Just kidding ofcorse. really nice set of goblets, and i'm still trying to figure out how ya done it.
    Cornwall, England
    392
    Quote Originally Posted by Stephen Bellinger View Post
    Oh come on I thought everyone knew this trick?
    At someone's suggestion on another forum I am thinking of adding a ball and chain but can't make my mind up whether it should go on his or hers
    Thanks for the comments everyone. I hope the buyer likes them as much
    Pete
    3,132
    Quote Originally Posted by Pete MoncrieffJury View Post
    Pete
    not me as i'm still a rookie. i think you might as well put it on his as that's the way it is over here.
    Cornwall, England
    392
    Sorry...Captive rings are made by cutting the stem part way and then making the ring. You turn the wood to the outside diameter of the ring and shape it. You then cut under from both sides until the ring is released onto the stem. Fix some abrasive (sticky back is ideal) on the stem then, running the lathe, you can clean up the inside of the ring. In this case I made two small ones that stay on the stem. The third was made and sanded lthe same way but larger and then cracked across the grain so the join wouldn't show, threaded through two of the rings, one on each goblet, glued back together with CA glue and sanded back to hide the join. You can get a tool to do the rings or, if you are clever it can be done with a skew. (I have the tool as it's quicker, easier and I do a fair few of these as wedding goblets for the Bride and Groom to do the toasts.)
    Hope that explains it. If not have a look here
    pete
    THanks Pete, I knew how the rings were done but the 5th ring had me puzzled.
    3,132
    pete
    Pete had a idea how the rings on the stems were done. Just coun't figure out how you got the one to hold the two together. thanks now i think i got it.
  1. I almost joined the Hereafter
    By Charles Lent in forum Off Topic Discussion
    Last Post: 05-05-2016, 11:55 AM
  2. my nephew patrick has just joined up with us
    By Dan Noren in forum Welcome and Introductions
    Last Post: 07-15-2012, 11:06 PM
  3. I joined a club
    By Mohammad Madha in forum Off Topic Discussion
    Last Post: 01-10-2012, 09:57 PM
  4. Joined the Club
    Last Post: 02-02-2010, 02:02 PM
  5. Hello to all that joined recently.
    By joe blankshain in forum Welcome and Introductions
    Last Post: 12-10-2006, 12:27 AM
