Results 1 to 8 of 8
Thread: Thank you Dave Richards
    Well Dave here is my latest attempt to draw with sketchup. I made one of each piece, saved them as components, copied the required amounts and am able to move pieces around without distorting anything else. Thank you again for the time you took on the phone with me today. It was invaluable.
    latest table.skp
    I can't seem to pull components back up that I've saved and named. I'm sure it's staring me in the face but can't remember.
Name:	latest table (800 x 410).jpg
    Alan,
    I think it's from the pull down menu: window - components. A pop-up should then show what you have in the drawing. Click on it and drop it in.
    Oh, and the table looks good!
    Wes
    SE Minnesota
    2,526
    Good work Alan. And you're quite welcome. You got the bead on the apron just the way we did it earlier today and you did a good job profiling the edge of the top and shaping the legs.
    As to getting the components again, did you save the components to some other location other than the In Model library? If not, open the Components browser and click on the little arrow that points out to the right. Choose Open or Create a Local Collection. Navigate to the Components folder and highlight it. Then click on Make New Folder. Give the folder a name and click OK.
    Now, select that folder in the drop down list where it says Google. With the folder selected, click on the right-pointing arrow again and choose Add to Favorites.
    Next, click on the little + icon in the upper right corner of the Components browser. this will open the secondary pane. Set one of the panes to In Model (drop down) and the other to your new folder. Click on the component thumbnails in the In Model pane and drag them to the other pane.
    Let me know how that works for you.
    Now, not to nit pick but check all of the mortises and tenons. One of the tenons needs adjustment. Use the X-ray view to see that. There's also an unneeded line sticking up from one corner of the top.
    Keep up the good work.
    Dave
    Ok I did the corrections. Rather easy when you have a good teacher.
    SE Minnesota
    2,526
    Thanks Alan.
    Did you figure out how to save the components? I'm available this evening if you want another look at that.
    I'm getting ready to try it out.
    SUCCESS!!
    Dave strikes again! Well done, gents.
    SE Minnesota
    2,526
    Quote Originally Posted by Alan Bienlein View Post
    SUCCESS!!
    Woo Hoo!
  1. Calling Dave Richards.....Paging Dave Richards......
    By Ken Fitzgerald in forum Designs, Plans and Sketches
    Last Post: 12-06-2012, 06:03 PM
  2. Calling Dave Richards! Dave, what's your twenty?
    By Bill Lantry in forum Off Topic Discussion
    Last Post: 07-11-2008, 09:46 PM
  3. Dave Richards, I see you did it again........
    Last Post: 11-17-2007, 01:08 PM
  4. Welcome Dave Richards
    By Vaughn McMillan in forum Welcome and Introductions
    Last Post: 11-23-2006, 04:03 PM
