Results 1 to 6 of 6
Thread: I hate to ask this....
    Dec 2008
    Santa Claus, In
    4,779
    How long do your normally keep an end grain cutting board clamped up? It is in a warm environment. I am thinking about 8 hours.
    Secondly, how much should one charge for a board like Wood Whisperer's? I am thinking $35 range.
    Reason I ask the last, is I am making some for gifts and neighbor lady seen them and wants some made. Hence the reason for the glue up times.
    17,477
    havnt made a end grain board but have glued up a fair amount of panels and a hour is sufficient enough to run threw a drum sander or a shaper or router table..at least i have had luck to do so..if you can leave them over night you definatly safe...priceing will have to come form others here.
    Austin, Texas
    1,448
    With most PVA glue - the yellow wood glue - the clamps can come off after an hour or so, but the full strength isn't achieved until 24 hours or more.
    I take the clamps off to go on to another piece, but don't consider the joint dry and strong until the next day - and the moisture won't be out for several days, so (in other situations) don't sand for several days, or a low area will appear as the moisture dries from the glue if you sand flat too soon.
    Charlie Plesums, Austin Texas
    Oliver Springs, TN
    1,726
    I've sold a few end grain boards and I usually charge in the 35 dollar range depending on the size. Most I have made are usually between 9.5 to 13 inches wide and 15 to 18 inches long.
    I've made one in a weekend before. I started early Saturday and got the first glue up done. I then cut it and did the second glue up late that afternoon. I let it set over night and most of the second day and finished it late Sunday afternoon. I don't like doing it this way but it was a rush job. As far as I know it's still holding up.
    Dec 2008
    Santa Claus, In
    4,779
    Thanks for the advise. I figured I was a little long on the time.
    Oct 2009
    Bradford, Vermont
    425
    If it's really well fitted... it doesn't actually need clamping at ALL. You CAN make a rubbed joint with PVA, and its' every bit as strong & thin as a clamped joint. Very often stronger, even, since there's little risk of glue starvation in a rubbed joint.
    That's if it's really well fitted & true.
    -- Tim --
  1. I just hate it when I.....
    Last Post: 04-22-2012, 09:29 PM
  2. Sometimes you hate being right.......
    By Ken Fitzgerald in forum Off Topic Discussion
    Last Post: 10-09-2009, 02:49 AM
  3. Don't you hate it when.....
    By Jeff Horton in forum Off Topic Discussion
    Last Post: 10-01-2009, 12:49 PM
  4. Hate to tell you this
    By Howard Wilson in forum Off Topic Discussion
    Last Post: 01-14-2009, 12:32 AM
  5. Man I hate this when it happens......
    By Stuart Ablett in forum General Woodturning Q&A
    Last Post: 11-04-2006, 07:09 PM
