Results 1 to 7 of 7
Thread: Finish for white oak dining chairs
    Central PA
    638
    I have 10 white oak dining chairs that I am getting ready to finish. The matching table is finished with minwax polyurethane. I was thinking of just using the same for the chairs but I am going to re-level the table and refinish it since it warped since the wood was too moist when I built it so I can use whatever for the chairs and just use the same when I redo the table. I am in the process of scraping the chairs smooth with a card scraper. Do I need to sand them after they are scraped? I remember that I had to sand the table after it was scraped smooth. When I finished the table I did not sand it and the second coat of poly started to pull the first coat off the wood so I had to strip it and start from scratch, I sanded and everything was fine. I know I have read several places about people just planing and scraping then finishing and no sanding. Is the polyurethane just not good for doing that, or should I have thinned it before applying it if its not sanded? If possible, I would like to spray the finish since I have 10 of them to finish and theres a lot corners and whatnot, and I would prefer not to have to sand all of them after I scraped them. I scraped them instead of sanding them because there was some blackening that happened when they were glued together and scraping is much faster than sanding... and its quieter. Any ideas for what finish to use and how to prep it?
    Quote Originally Posted by Dave Black View Post
    Dave, I have found that if you don't let the poly fully dry between coats it will solve the pealing problam. as for sanding after scraping, is the surface smooth, if so the don't sand it.
    Central PA
    638
    Yeah... no sanding, if you can't tell I hate sanding. It makes sense about letting the finish dry fully. When I did the table I let the finish dry the minwax recommended 4 hours. When it started to peel I called minwax and the person I spoke to was kinda baffled, she then talked to somebody else that was there and asked me if it was sanded, when I said that it was scraped she told me to sand it before applying the poly. Any thoughts about polyurethane vs polycrylic or other finishes. These chairs are going to be used and abused daily. In the past I have had good durability with polyurethane but I don't have much experience with the polycrylic. From what I hear the polyurethane yellows the wood some, and the polycrylic doesn't. I don't have any comparison so I don't know. I am not sure if I would want the yellow or not. Heres a pic of the table right after it was built and one of the glued up but un-scraped chairs.
    30,008
    Dave, I've used Polycrylic for a number of shop fixtures and jigs, and it's proven to be real stout stuff. I've also had pretty good success spraying it with a cheap HVLP spray setup like this one from Rockler.
    Central PA
    638
    I have a high pressure sprayer like you would use for painting cars. Its an older one, not gravity feed, but it works fine, I used it to spray poly on a computer desk and got great results, If I remember right, I didn't thin the poly when I sprayed the desk, but I seem to remember thinking that it would have been helpful.
    Central PA
    638
    If all goes well I should be shooting polyurethane on the chairs tomorrow. Any last words before I pull the trigger (pun slightly intended) Should I thin the poly when I shoot it, or just let it as is as long as it sprays fine?
    Woodstock, Ontario, Canada
    719
    Wipe on poly sprays real good , right out of the can!. After having poor results wiping on 4th- 5th coat, I tried the Wagner plastic gun HVLP set up I have and it really sprayed on nice.
    hobby woodworking since 1972
  1. dining room chairs
    Last Post: 10-29-2016, 12:44 AM
  2. Dining chairs-mahogany(and sapele), the work is slow going,
    Last Post: 09-22-2013, 05:52 PM
  3. Repair - Refinishing of six dining room chairs
    By Mike Henderson in forum Flatwork Project Showcase
    Last Post: 02-28-2013, 02:34 AM
  4. Ash/Oak Dining Chairs
    Last Post: 09-12-2010, 11:51 AM
  5. Batch of mesquite dining chairs
    By Kirk Constable in forum Flatwork Project Showcase
    Last Post: 02-06-2007, 05:13 PM
