Results 1 to 7 of 7
Thread: Taper Lock
    S E Nebraska
    35
    Taper Lock
    I just posted this on Traditonal Tools Site.
    FWIW on taper locks.
    I use round taper locks as they are a lot easier to make and work with, but this theory works with square or rectanguler taper locks also.
    This is one of my Depth gauges that uses a taper lock.
    And this is a pair of African Walnut Dividers that uses the same thing to lock it in position.
    This is a basic drawing of the principle.
    The trick is to drill the holes so they overlap just a tad. And a long slight taper works better than a short steep taper as it has a lot more holding power because it wedges easier and tighter. The tapered wedge is captive so it can't come out unless you remove what it is holding in first.
    Just thumb pressure is all that is needed to positively lock it, and finger pressure on the other end will release it easily.
    Red dashed line is the drilled hole, Green is the wedge, black is the captive bar. Gray is the housing.
    I make my own dowels from native woods, but a common hardware store dowel will work just as well and you can stain it any color you want.
    I hope this helps someone
    Drawknife, Spokeshave, Plane, Rasp; Decisions, decisions.
    Old tools are all very MODERN, they are all CORDLESS.
    By Hammer and Hand All Arts Do Stand.
    thanks jr.! great idea..
    15,816
    Jr. that is great, I've not seen one like that before, very useful!
    Thanks JR, thats realy clever.
    S E Nebraska
    35
    One little trick I forgot when using this system for a marking gauge to keep it oriantated all the time, Plane a small flat spot full length of the bar where the wedge makes contact.
    Nova Scotia's beautiful south shore
    443
    Great stuff, Jr ! I've been looking at panel gauges with a view to making one. This could be the answer for my locking mechanism.
    All the best,
    Ian G
    **Now holding auditions for a catchy new signature**
    Charlotte, NC
    1,487
    Thanks Jr., Great system!
  1. Taper Jig - Straight Rip Jig
    Last Post: 09-14-2014, 04:19 PM
  2. Taper Jig - Blade Choice?
    By David Agnew in forum Jigs and Fixtures
    Last Post: 01-11-2014, 08:38 PM
  3. loose morse taper
    By gary doby in forum Turning Tool Questions and Show & Tell
    Last Post: 01-09-2008, 02:27 AM
  4. interesting taper method
    Last Post: 07-02-2007, 05:53 AM
  5. Lets See Your Taper Jig !
    By Sean Wright in forum Jigs and Fixtures
    Last Post: 05-28-2007, 04:55 PM
