Results 1 to 10 of 10
Thread: Straight edge for setting TS wings and extension table.
    2,784
    Ok, I'm close to ordering my new TS (Grizzly G0691) and I'm going to need to be able to get the set up done right. I have a dial indicator and magnetic base so I can set the blade and fence parallel to the miter slots. I have a decent, not great, Rockler square for getting blade at 90 degrees to the table. What I don't have is an accurate straight edge. With the long extension table (saw comes with 50" rip, and I may eventually get longer rails for my Biese fence and use the Griz fence on the contractor saw) I feel I need something to accurately level the saw extensions, and then the extension table.
    Question...How long of a straight edge do I realistically need? Is 36" long enough, or do I need 50"? I can get a 36" one from Infinity for 54.95 less 10% discount and probably go ahead and get a blade for my SCMS at the same time to get to the free shipping. I think they still offer that. Or I can get an aluminum 50" Veritas from Lee Valley for about 90.00 shipped. I'm just not sure which length I really need.
    Thanks for any insights you can offer! Jim.
    Coolmeadow Setters...
    Exclusively Irish!
    3,134
    I have the Wixie model of this but this should work just as well I know it works easier than a bevel square & protractor to set your blade angle including 90 degree settings.
    http://www.rockler.com/product.cfm?p...campaign=V0716
    Why couldn't you use a straight ripped piece of plywood? I don't think it's like checking a automotive head for flatness before mounting it on the motor block.
    5,175
    I use a 6 foot level for a straight edge and a drafting triangle for setting the blade. For angles other than 90 I use an adjustable drafting triangle.
    It's inexpensive and I have found it to be very accurate. My bench mark is a quarter of a millimeter for the work. The tools have to be dead on.
    My toy budget doesn't extend to every tool out there. I have to be choosy.
    I have the Lee Valley and find it very useful for alignment and such.
    DP
    Dale Probst
    www.wardprobst.com
    5,323
    I use a 6 foot level for a straight edge...
    That's what I use, too.
    I do have a 24" 'precision straight edge,' but the level works just fine for longer jobs.
    Oct 2009
    Bradford, Vermont
    425
    For that sort of purpose, a 4' framing level is totally satisfactory... or any length of aluminum extrusion (which is surprisingly accurate).
    -- Tim --
    9,077
    I'll be the contrary guy. My builder's level, confirmed to the degree of my ability, was way off relative to leveling/flattening my router table top (and I thought I had it so right). The problem exhibited itself on the more complex interlocking type of profiles. The wood was not approaching the cutter over a good path so the result was poor. The straight edge made this super obvious where I had missed it before. A set of long feelers, some shims and less time than I'd have thought and things were set right; problem gone.
    OK, armed with that success, I started looking around. A straight edge also exposed my 'up till then, so trusted' level's limitations when applied to my tablesaw wings and top. Cast iron is relatively flexible and you can cure all manner of ills with a little tweaking.
    A 36" has always met my needs and has not proven too long and unwieldy for most smaller work. Over a 50" span, my tolerance would loosen up quite a bit. The edge of a sheet of 40" ply at 90* or 90.5* is not going to kill me. At the supported path to cutter area interface, small "slants" can cause later headaches during fitting and assembly of more precision joints (especially if they are for show).
    I wouldn't kill myself over things that don't actually effect the result I am after. My outfeed table is far from perfectly aligned but it does not interfere with my results. If you find things not quite right in an area that is important to you, having the tools to fix that sort of thing can be very handy.
    I only use my straight edge a few times a year. When I do, the work is quick and accurate thanks to having it. Could I live without it? Sure, if I'd never had one . Good luck getting it away from me now
    P.s. Speaking as one who has recently 'gone back' to do a better job; set your blade to miter alignment (at 90* and 45*) before assembling your wings and such. I know you'll be excited to put it together but this step will increase your enjoyment of the machine from here on out. It is far easier to change shims (if required) when its just you and the saw body working together. Once the wings and such go on, you may lose some alignment but the corrections for this will be minor and should be doable without pulling the top. Have fun and I'm jealous.
    Don't listen to these guys. This is what you need http://www.amazon.com/Starrett-380-7...5&sr=8-4-spell
    Made in the US and garranteed forever
    a 36 inch steel straight edge from lee valley($69) should work fine if you want to be precise(could also be useful in setting up jointer/planer beds) Or if you've got a decent level that would work too.
    I have a 24" straight edge from woodcraft is it good, but I sometimes wish I had the 36" unit, not often but sometimes, the thing is, the 36" tool is expensive to ship to Japan.
    I use an aluminum 38" Veritas straightedge for my jointer and to check the router table itself, and a good 4' builder's level for the tablesaw and its relation to the wings (including the router table side).
    And oh yeah...I use the Beall Tilt Box for setting blade angles, and use plastic drafting triangles to confirm when setting to 90 or 45. (And I don't use the built-in tilt stops at all.)
  1. Straight Edge
    By Mohammad Madha in forum General Woodworking Q&A
    Last Post: 12-16-2011, 03:35 AM
  2. Extension wings for my new scms
    By Alan Bienlein in forum Carpentry and Construction
    Last Post: 09-22-2011, 09:59 PM
  3. Questions on straight edge
    Last Post: 12-31-2007, 10:11 PM
  4. Straight edge on table saw
    Last Post: 11-28-2007, 02:51 AM
  5. Veritas Straight Edge Surprise
    Last Post: 10-10-2007, 11:51 AM
