Results 1 to 10 of 13
Thread: Lamp
    11,832
    Lamp
    Hey, Ned! Recognize that hunka walnut?
    When Rennie came for his tour visit, he brought this nice hunk of walnut that Ned had thoughtfully sent for me. (Thanks, Ned ) I wasn't sure what to do with it and kept until an idea came along that wouldn't require me to cut it into little pieces. My daughter and daughter-in-law had each expressed the need for a bedside lamp. Daughter won first dibbies because, well....she is my daughter. DIL will get one later.
    Of course, the walnut would be turned and as much of the wood as possible saved. That led to my first lesson in lamp making.
    See: http://familywoodworking.org/forums/...ad.php?t=16769
    The turning part was pretty straight forward but, I think, the top section looks a little top heavy. If I were to do it again, I would make that a smaller, lighter looking diameter.
    The base is maple, with a portion a bit spalted. Originally, the spalt part was to be in the rear out of sight. But, wifey said it complemented the dark walnut. Ain't gonna argue with wifey. Spalt is in front.
    Another lesson came in ordering the parts. That is discussed in the first thread. Now I know where to get parts at reasonable prices.
    My original design was to center the upright portion on the base and drill large holes on each side to act as places to put things like rings, earrings, coins, used bubble gum...or whatever. I sent pics to my daughter and she preferred the, kinda modernistic, look of having the upright offset to the right and "no holes".
    All was good until I tried fastening the lamp to the base. Not as easy a task as I would have thought. I used about a 4" section of lamp type threaded, hollow rod, in the hole I drilled in the bottom of the upright. It was glued in with epoxy and let to set for a day. When I put the base on, the rod pulled right out.
    After much cussing, I cut another section of rod about 8" long and put in with Gorilla Glue (see: I hate Gorilla Glue). Now, I double hate it. When I tried tightening the upright to the base with the rod nut, the rod pulled loose immediately. Apparently the screw action of tightening the nut is very powerful and broke the glue seal. Bad news. So, then, I drilled a hole and glued in a 1/8" dowel to secure the two. Didn't work, 1/8" was simply not strong enough. I then drilled another 1/4" hole and glued in a dowel. That worked but it is still a bit wiggly on the base. The way the upright is turned, I don't have a lot of room for more drilling. Had I planned this ahead, the bottom of the upright would be wider and I would secure with two 3/8" dowels. Or, for other model lamps, I would use a full-length threaded rod and secure by tightening the nuts from both ends.
    Future lamps, and there will be future lamps, will be pre-designed to avoid this problem. Like the old story goes: the first custom made item costs the customer $500.00, those afterwards are $50.00 each.
    All in all, I'm happy with the outcome even if the project tested my patience.
    Attached Thumbnails Attached Thumbnails lamp centered.jpg   lamp side.jpg   lamp finished.jpg
    Jul 2007
    DSM, IA
    5,719
    I agree with your wife, I like the spalt in the front. Well Done Frank.
    P.S. Glad you went thru the learning part for us!
    My Website
    Los Angeles, CA
    2,668
    The top does look a bit hefty but overall a nice lamp.
    Southeast Pa
    2,019
    Frank It all looks nice to me and I love the Base..
    Garry
    Atlanta, GA
    194
    Looking good, Frank. Where'd you wind up getting the hardware from- Walmart?
    11,832
    Quote Originally Posted by Charlie Schultz View Post
    Thanks.
    No. Local stores were no help.
    I ordered from Grand Brass: http://grandbrass.com/
    Kinda costly but good quality.
    Later, I was told about Lamp Stuff: http://www.profhdwr.com/lampstuff/
    Big selection and more reasonably priced.
    Considering the aggravation I went through fastening the base, I suggest you buy several 36" threaded rods to keep on hand if you plan to make more than one lamp. They are cheap but priceless if you need one.
    Dec 2008
    falcon heights, minnesota
    5,610
    good work on the lamp frank. if you ever make one with an s-type cluster, drop me a line, an old electrician friend of mine showed me an easy way to wire them.
    benedictione omnes bene
    www.burroviejowoodworking.com
    11,832
    Quote Originally Posted by Dan Noren View Post
    OK, thanks.
    Uuhhhh.....wassa s-type cluster?
    I want to use branches for the next one.
    Gotta find a way to drill curves.
    Dec 2008
    5,610
    an s-type cluster looks like an s when viewed from above.
    Central Illinois
    936
    Been a LOOOOOOOOOOOOOOOOOOOOOOOOOONG time since I worked on a lamp.
    Don't remember ever gluing in the rod. The tension caused between the top nut and a washer with nut on the bottom was enough to hold everything in place. BTW, the hole is only just big enough to let the rod slide through.
    Bruce
    Bruce Shiverdecker - Retired Starving Artist ( No longer a Part timer at Woodcraft, Peoria, Il.)
    "The great thing about turning is that all you have to do is remove what's not needed and you have something beautiful. Nature does the hard part!"
  1. Lamp that took forever
    By Dennis Kranz in forum Lathe Project Showcase
    Last Post: 10-30-2012, 10:24 PM
  2. Drilling a lamp
    By Dennis Kranz in forum Turning Tool Questions and Show & Tell
    Last Post: 07-01-2010, 03:53 PM
  3. Lamp
    By allen levine in forum Lathe Project Showcase
    Last Post: 10-22-2009, 04:05 AM
  4. Floor Lamp
    By Dave Black in forum Flatwork Project Showcase
    Last Post: 08-31-2009, 11:24 AM
  5. Lamp
    By Jeff Horton in forum Designs, Plans and Sketches
    Last Post: 05-08-2007, 11:07 AM
