Results 1 to 8 of 8
Thread: Sheet Goods Cutting Cart
    Manistique, Michigan
    297
    Sunday afternoon, I made this cart so that I can use the EZ Smart to break down sheet goods without having to cut the sheets on the floor. I can tip the sheets off the shelf onto the cart. The cart top is about 30" off the floor - just about right for me to use the circular saw on the saw guide.
    I got the cart from work. A piece of equipment we bought was shipped on it and no one wanted the cart, so I got permission to take it.
    The frame is made of 2 x 4 with piece of plywood on top. Then I took strips of plywood and made the sacrifical lattice. The lattice ended up 44" x 60".
    Attached Thumbnails Attached Thumbnails PB260505.jpg   PB260506.jpg   PB260507.jpg
    Rich (the Yooper)
    "To the world, you may be one person, but to one person, you may be the world."
    "Common sense is not so common."
    That should be handy for a number of things. Not only a cutting cart, but with a piece of scrap ply or MDF on top it's spare work surface (or tool depot).
    297
    I had not thought about using it for a work surface. Good idea.
    Rich (the Yooper)
    17,474
    good use of some scrap from work rich,,, will work for trimun venison to
    297
    Larry, Another good use for the cart,eh!
    The cart does take up a lot of room in the shop, but it also makes handling the sheets a lot easier. The storage is at the back end of the shop, which is not plowed in the winter so the double doors are not useable. I can use the cart to haul sheets to the back of the shop when I buy a new batch.
    Rich (the Yooper)
    Good stuff there Rich.
    297
    I used the cart yesterday - it really works well. Even without locks on the casters, there is no issue loading and using it for cutting. In fact, sometimes it is more convienent to rotate the cart than walk around it.
    Rich (the Yooper)
    North West Indiana
    6,099
    Planer stored underneath it with a dust cover? Planer bolted to a thick plywood piece, could be clamped ontop for the occassional use. One less stand to walk/move around.
    Jon
  1. Cutting Sheet Goods -
    By Doug DeVore in forum General Woodworking Q&A
    Last Post: 03-27-2012, 04:55 AM
  2. Sheet Goods Cart
    By Wes Bischel in forum General Woodworking Q&A
    Last Post: 08-24-2009, 12:59 PM
  3. Folding sheet goods cutting table
    By Tony Baideme in forum Jigs and Fixtures
    Last Post: 02-10-2009, 09:36 PM
  4. sheet goods storage
    By Craig Johnson in forum General Woodworking Q&A
    Last Post: 01-20-2009, 05:59 AM
  5. Sheet goods storage
    By Jack Lemley in forum General Woodworking Q&A
    Last Post: 12-17-2008, 04:04 AM
