Results 1 to 10 of 16
Thread: How to keep the seams from showing up on MDF?
    Dec 2009
    Madison, WI
    206
    I have a set of unfinished MDF speaker boxes I'd like to finish, and was wondering if anyone has any tips as to how to prevent the seams from showing through the paint. The boxes were made some time ago and left unfinished, and the expansion of various relative pieces of MDF is visible; while the construction is solid, I'd like to know if there's anything I can do beyond sanding it flat and hoping for the best.
    Incidentally, can anyone tell me how to figure out if my black shellac is past-due?
    17,472
    to me if you have seems that you dont want to see you need to cover them up with a solid piece rather than a two piece cover.. and as for the shellac try a sample out on so scrap and see if it drys.. if it does you should be ok to go
    Dec 2009
    Kemah, Tx. - Houston Suburb
    95
    Bondo
    I have always used automotive Bondo. Takes a few minutes to mix and apply. About 10 minutes till you can sand flush with a belt sander.
    Dec 2009
    Madison, WI
    206
    Quote Originally Posted by Tony Bilello View Post
    I'll give it a try.
    What should I do to bondo before I can shellac it?
    Oct 2009
    Bradford, Vermont
    425
    Quote Originally Posted by Joseph Shaul View Post
    I'll give it a try.
    Just sand it to a finish surface (320 or better).
    Black shellac???
    -- Tim --
    Dec 2009
    95
    Tim
    I seem to be running into lots of people from another life, on here.
    Oct 2009
    Bradford, Vermont
    425
    That happens.
    -- Tim --
    10,604
    Veneer ?
    Dec 2009
    Madison, WI
    206
    Veneer ?
    The box has a roundover on both the top and sides - otherwise, I'd have taken the easy option. That said, I have seen seams poke through veneer before - maybe a laminate of 1/64" plywood layers before the veneer would prevent this?
    Quote Originally Posted by Tim Hofstetter View Post
    Black shellac???
    I have no idea exactly what the stuff is, but it was free and it's supposed to work very well. I got it from another DIYer who was moving to an apartment and clearing out his stuff.
    Dec 2009
    95
    Joseph
    I dont ever use anyones leftover finish. Too many unknowns such as how old, temp. extremes at which finish was exposed too, contamination, etc.
    It's a gamble.
  1. FYI: The Scumbags are already showing up
    Last Post: 04-19-2013, 02:22 AM
  2. Just showing off
    By Chuck Ellis in forum Lathe Project Showcase
    Last Post: 02-02-2013, 06:19 PM
  3. Pictures not showing in posts - again
    By glenn bradley in forum Site Questions and Test Posts
    Last Post: 05-31-2009, 04:40 AM
  4. just a little showing off
    Last Post: 12-22-2007, 03:08 PM
