Results 1 to 10 of 19
Thread: Purpleheart
    Puyallup, WA
    330
    Purpleheart
    I just finished up a few Christmas gifts that I made out of purpleheart. Unfortunately, due to all the cutting, sanding, etc. the "purple" has been mostly taken out of the "purpleheart". I realize that left exposed to UV sunlight, it will (supposedly) revert to its once regal color. However, and to the essence of my dilemma, we presently have very little, if any, sunlight and the forecast is not looking promising anytime in the near future. Do you think if I set it under an artificial light source it would speed the process up? If so, do you think it matters what type of light it is (e.g. fluorescent, incandescent, halogen, etc)?
    17,471
    not sure of purple heart but in cherry i tried to hurry the process of color taning on a door that i replaced a broken one .. i used a tannin bed for 20 mins and got very little change.. i ended up taking it to work with me and let it get all of the natural uv i could feed it.. i dont thik that artifical light is gonna do it for you and also its the air that does the color change process as well, not just light.
    Oct 2009
    Bradford, Vermont
    425
    Larry's right on it there - UV accelerates the wood's ability to oxidize, which will happen only in the presence of oxygen (as from the air). If it's been finished, particularly with a yellowing finish like polyurethane, it'll change color very slowly henceforth.
    If any light will do it, a black light (available from your friendly Borg) is the light that will.
    -- Tim --
    5,320
    Actually, I believe that UV exposure will actually turn the purpleheart to brown. It's lack of UV exposure that lets it keep its color.
    Sanding should have enhanced the purple - unless it's sapwood, which is naturally brownish.
    3,132
    Jim in my limited experience after sanding or turning it. you can help bring back the color by placing it a window. I have a piece in my truck that has been sitting behind the seat that was turning brown. after putting on the dash it turned back to the purple it was.heres a pic of my tool box that is trimed in purplehart and as you can see it has stayed purple for over 4 years. After sanding when i first made it it had turned brown so i put it where the sun shown on it and it has been purple ever since.
    Oct 2009
    Bradford, Vermont
    425
    Upshot... purpleheart is a funny wood. Sometimes it goes from brown to purple, sometimes from purple to brown. It's unpredictable.
    -- Tim --
    Puyallup, WA
    330
    Fortunately, I haven't put any finish on it yet. I guess there's nothing else to do but experiment. I'll leave one in the window, put one under incandescent light source, one under Halogen and will look into the cost of a UV bulb. I think I'll also see if the presence of an acid will accelerate the process (hence the reduction part of the oxidation equation).
    I'll let folks know if anything works.
    PS - if I wasn't clear enough before, the stuff was startlingly purple before machining.
    Oct 2009
    Bradford, Vermont
    425
    Also try household-strength ammonia & dilute Red Devil lye. Lye does MARVELOUS things to cherry.
    -- Tim --
    Dec 2008
    falcon heights, minnesota
    5,609
    what about those grow bulbs that help plants along? one would think they would provide the same spectrum as sunlight.
    benedictione omnes bene
    www.burroviejowoodworking.com
    Puyallup, WA
    330
    It's funny what a little research will turn up. Apparently, a common black light is comprised of mostly UV light. So, first thing tomorrow I'll run up to Walmart and pick up the cheapest little set up they have.
    And, even if it doesn't turn the wood back to purple, I'm sure my teenage daughter will get a kick out of it.
  1. Finish for Purpleheart?
    By Earl Rumans in forum Finishing School
    Last Post: 02-05-2014, 10:47 PM
  2. re-purpling purpleheart
    By Dan Noren in forum General Woodworking Q&A
    Last Post: 07-20-2010, 01:03 PM
  3. PurpleHeart Jolly Roger
    By Kevin Vernon in forum Flatwork Project Showcase
    Last Post: 06-09-2008, 12:29 PM
  4. purpleheart & white oak cradle
    By Dewayne Baker in forum Flatwork Project Showcase
    Last Post: 01-08-2008, 01:44 AM
  5. Purpleheart & Maple
    By Ed Nelson in forum Lathe Project Showcase
    Last Post: 04-09-2007, 01:17 PM
