Results 1 to 10 of 12
Thread: Delta 46-700 Lathe
    Manistique, Michigan
    297
    Delta 46-700 Lathe
    Does anyone have one of these lathes? Would it be a decent starter lathe?
    Rich (the Yooper)
    "To the world, you may be one person, but to one person, you may be the world."
    "Common sense is not so common."
    Goodland, Kansas
    4,834
    Rich the one I have seen had lots of problems with the reeves drive. A friend of mine had one, sold it after a year and bought a Jet 1642 1.5 hp. He had nothing but problems with it from about the first month. He fixed it more than he turned on it. Like I say that is the only one I have seen. I would look at the new Delta 46-460 VS. Nice lathe and solid.
    Bernie W.
    17,475
    or a oneway 1224. is supposed to be a good one rich.
    Feb 2009
    Whittier, CA, USA
    512
    Hello Rich,
    I have one of these. It works well for me. I use it mostly as a utility tool turning pieces for repair and replacement (handles, knobs, spindles, cups).
    I ended up with it after some equipment horsetrading. I took the legs off, mounted it on a piece of ply and clamp it on my bench as needed. It weighs about 100 pounds without the legs and it lives underneath my bench when not in use.
    I have never had any problems with it. It has MT2 tapers at both ends and a 1"x8 spindle, so very easy to get accessories and migrate them to a new lathe.
    If I hadn't gotten it as part of another deal I would take caution of its inherent shortcomings.
    1. lightweight stand
    2. not a low enough slow speed for large diameter pieces
    3. a little underpowered for heavy pieces
    If you can buy it in great condition for less than $200 and take care of it. I am sure you will get your money back if you decide to sell it and upgrade at a later time.
    Hope this helps.
    Cheers,
    Dan Gonzales
    Whittier, CA, USA
    Dona nobis pacem
    You do know the little Oneway 1224 is only about $2400, right?
    17,475
    yup,,yu get what you pay for i hear on this place called FWW
    i do listen to those that know..
    Sep 2007
    Mountain Home, AR
    6
    I had one of those jobbys. Went and got myself a 3 phase 1HP inverter duty motor, a 220 volt inverter. Now its like my Jet 1642, 0-3000rpm, forward/reverse capability. now a good little lathe.
    297
    Thanks for the input. I found one for about $400 with tools, but I haven't been able to find reviews of it. There was info about the weight and that had me concerned.
    Roger, I considered doing that conversion. An ABB inverter drive through our supplier is about $175 for up to a 2 hp motor and put on a three phase motor. Glad to hear from someone who has sucessfuly done this type of conversion. Did you keep the Reeves drive or did you put on a different set of sheaves and belt?
    If I found a Jet 1442 used, I would definitely do this conversion. I am still considering the Delta.
    Rich (the Yooper)
    Feb 2009
    Whittier, CA, USA
    512
    I don't think this is the machine to juice up. I forgot to mention in my previous post that the headstock is a pretty light casting concealed in plastic.
    It would be a good value for less than $200 just as is. But not really a great machine.
    Dan Gonzales
    Whittier, CA, USA
    Dona nobis pacem
    Tellico Plains, Tennessee
    4,353
    Quote Originally Posted by Rich Aldrich View Post
    I have a Jet 1442... have wondered if it could be converted... don't know that I will but good to know it can be. Right now I think my Reeves is out of alignment... the 450 rpm bottom speed seems faster than the 500 rpm bottom speed on my Jet 1014. Also, I just bought new belts to change the original belt... it's getting pretty frayed and I expect it to part anytime, so as soon as it warms up a little, I'll change it out before it does break.
    Chuck
    Tellico Plains, TN
  1. Anyone have the Delta 46 460 Lathe?
    Last Post: 05-09-2014, 02:40 AM
  2. What happened to the Delta 46-460 lathe?
    By Tom Baugues in forum Turning Tool Questions and Show & Tell
    Last Post: 12-31-2011, 12:52 AM
  3. new Delta mini lathe
    Last Post: 08-19-2009, 06:35 PM
  4. Delta 46-623 lathe (not mine)
    By Billy Burt in forum Hot Deals
    Last Post: 12-13-2007, 08:14 PM
  5. Delta Midi Lathe
    Last Post: 03-06-2007, 04:03 PM
