Results 1 to 10 of 20
Thread: WIP - Mason's 4 poster Bed
    Woodstock, Ontario, Canada
    719
    After letting the turned parts sit for a whole year, I hauled them out to try and finish this project of my grandsons bed. After the glue up of 2x6 maple, had several problems with cracking, glue joint failure. After some repairs, re-turning on the lathe, I was fed up and tossed it under the bench . With this years presents done, I pulled out the turned parts, no more cracking, etc. Did some repair by gluing wood in the cracks. So I laminated up the 4/4 maple into the headboard yesterday, then glued on a trim piece for the top. Today I cut out the headboard, cut mortises and did some fitting. Some pics from last year and yesterday and today's progress.
    hobby woodworking since 1972
    new york city burbs
    10,188
    your bed post spinning is spectacular.
    May I ask, did you do the entire piece besides the cap of the leg/post as one piece?
    17,472
    good save bryon,, if only all troubles ended like that
    719
    pics 2& 3 are the two main pieces. I had help with the turning from this attachment!
Name:	Vega copier-1.jpg
ID:	40426Turning section for pine cannonball bed
    719
    Finished up fitting the other post by supper. Starting to look like a bed, a very heavy bed!
    719
    Giving the mortiser a workout! Quickly cut the two tenons on TS, clean up with my new LV bull nose plane.
    Dry fit of footboard.
    10,604
    Beautiful Bryan
    The butternut post on the bed I'm making has developed a crack like the one on yours. I was wondering about the best way to repair it. I was going to put a few screws in and plug them but I think I'll try your method.
    12,256
    What a grand bed Those ends must be pretty solid and heavy Eh? Nice work and i like the way you seem to be setup to be able to get a good run at a project in your time in the shop. Keeps the motivation up.
    Thanks for sharing.
    719
    got the metal hangers mounted in the posts and end rails. test of parts pic
    719
    UPDATE!
    2 coats of stain and 1 coat of lacquer on so far today
  1. Mason Bees?
    Last Post: 03-06-2013, 02:40 AM
  2. poster source?
    Last Post: 07-28-2012, 06:54 PM
  3. 1919 Poster
    Last Post: 12-28-2011, 04:54 PM
  4. 4 poster bed Project
    Last Post: 11-09-2011, 11:13 AM
  5. Mason - Mix'n Line
    By Rennie Heuer in forum Finishing School
    Last Post: 08-30-2008, 02:03 AM
