Results 1 to 7 of 7
Thread: juice groove
    Apr 2008
    Butte Montana which is 1/2 way between Purgatory and Heaven
    170
    juice groove
    How do I cut a juice groove on a cutting board? Do i need to make a template?
    Thanks
    Jiggs Elphison
    30,015
    Jiggs, the one time I did a juice groove on a cutting board, I used my router table with stops attached to the fence on either side of the piece to limit how far I could cut in either direction. It was a pain doing it this way. It took a lot of figuring and experimenting to get stop blocks positioned to stop the cuts in the right places. (And I had to set them twice...once for the long sides of the cutting board and again for the short sides.) Also, I had to start the cuts by pushing the board down on top of the spinning router bit. Since I took light cuts, I had to do that maneuver multiple times.
    I think either a template or a clamped-on straight edge (being careful to not cut too far) would be easier to deal with and get good results.
    I would use a streight edge and a plundge router.
    Apr 2008
    170
    juice groove
    Thanks for your tips, i figured straight edges , my main concern is the corners, maybe I'd be smart to make a template out of MDF. Yhanks again for your tips -
    merry xmas to everyone
    Jiggs Elphison
    5,321
    I'd make a template from MDF, double-face tape it to the board, and use a template guide in my plunge router.
    Make the channel about a quarter inch deep, in two passes. First pass maybe 3/16" deep and the finishing pass to full depth.
    I'm with Jim. Its almost too easy.
    NH
    4,005
    I would go with Jim"s way too.
    Unless you have one of those cool carvers like Stu has.
    Stupid hurts.
  1. Should I Add a Bead or V Groove...
    By Bill Satko in forum Neander Woodworking Q&A
    Last Post: 01-11-2012, 12:21 PM
  2. cutting board juice grooves...
    By Art Mulder in forum General Woodworking Q&A
    Last Post: 10-16-2011, 01:50 PM
  3. Plate groove
    Last Post: 01-12-2011, 12:10 PM
  4. V groove in log?
    By Virgil Huffman in forum General Woodworking Q&A
    Last Post: 12-07-2009, 10:16 PM
  5. Tounge & Groove Cabinet construction
    By Ron Roase in forum Flatwork Project Showcase
    Last Post: 11-01-2007, 11:11 AM
